Guest george Posted February 17, 2010 Share Posted February 17, 2010 Hi, its the same problem many people seem to have had. f reg mfi xr3i cabbie, it starts ok when cold, but when hot it wont start. ive put a new starter on as this seems to be the most common problem, but it still wont start! engine turns over and nearly gets there but not quite. it was working fine last summer, then i took it off the road, it only developed this problem when i took it for a spin up the lane one day after it was sat for couple weeks in the garage. cheers George Quote Link to comment Share on other sites More sharing options...
Guest shaggy Posted February 19, 2010 Share Posted February 19, 2010 Hi, its the same problem many people seem to have had. f reg mfi xr3i cabbie, it starts ok when cold, but when hot it wont start. ive put a new starter on as this seems to be the most common problem, but it still wont start! engine turns over and nearly gets there but not quite. it was working fine last summer, then i took it off the road, it only developed this problem when i took it for a spin up the lane one day after it was sat for couple weeks in the garage. cheers George i have the same problem on my mk3 i think its the cold start valve what happens is when the engine is warm and you go to start it it thinks its cold and is over fueling, let the engine warm up give it 10 mins then unplug the cold start valve and see if it fires up Quote Link to comment Share on other sites More sharing options...
Guest george Posted February 23, 2010 Share Posted February 23, 2010 cheers for that mate. ive had a little play about with it, but not enough time at the moment! hope it is the cold start valve, makes sense Quote Link to comment Share on other sites More sharing options...
gingergman Posted February 23, 2010 Share Posted February 23, 2010 let us know if it is mate when youve had time to play with it, if it aint then we can move on to the next thing lol, Quote Link to comment Share on other sites More sharing options...
