Guest bigburger Posted February 15, 2010 Share Posted February 15, 2010 Anyone know why my radio keeps loosing it's setting after ignition is switched off, i know it needs a constant feed from the battery but when i try that the fuse blows in the radio !! Any help or wiring diagrams would be awesome ! Steve Quote Link to comment Share on other sites More sharing options...
Guest XxpeteyxX Posted February 15, 2010 Share Posted February 15, 2010 (edited) normally the yellow is perminant live but on the escorts its the red so red from car to yellow on radio yellow from car to red on radio Edited February 15, 2010 by XxpeteyxX Quote Link to comment Share on other sites More sharing options...
Guest bigburger Posted February 20, 2010 Share Posted February 20, 2010 normally the yellow is perminant live but on the escorts its the red so red from car to yellow on radio yellow from car to red on radio Cheers Pete your abs right, but one slight problem, when i got it working, programmed and clock set and was sliding the radio back in there was a spark and flash and the radio went off, all the fuses in the radio are fine and didn't blow but now the radio won't power up ? any ideas mate ? Quote Link to comment Share on other sites More sharing options...
gingergman Posted February 20, 2010 Share Posted February 20, 2010 sounds like a wire was exposed and touched the cage, check the car fuses aswell, also have a look at the wires and see if any have melted Quote Link to comment Share on other sites More sharing options...
