Guest lambrettaman Posted February 12, 2010 Share Posted February 12, 2010 front windows and roof wont operate mk5 xr3i any ideas cheers ps they were working fine Quote Link to comment Share on other sites More sharing options...
Guest traceyswifti Posted February 12, 2010 Share Posted February 12, 2010 what did you do for them 2stop working Quote Link to comment Share on other sites More sharing options...
gingergman Posted February 12, 2010 Share Posted February 12, 2010 first off check the fuses mate, try the simple things first, did they both stop working at the same time? Quote Link to comment Share on other sites More sharing options...
gingergman Posted February 12, 2010 Share Posted February 12, 2010 what did you do for them 2stop working if he knew that he wouldnt be asking lol Quote Link to comment Share on other sites More sharing options...
Guest shaun Posted February 12, 2010 Share Posted February 12, 2010 try isolater switch is not push in or as gingerman said try fuses Quote Link to comment Share on other sites More sharing options...
Guest lambrettaman Posted February 12, 2010 Share Posted February 12, 2010 what did you do for them 2stop working Quote Link to comment Share on other sites More sharing options...
Guest lambrettaman Posted February 12, 2010 Share Posted February 12, 2010 had knacked battery put new one on dont work tred old battery they work but car wont start Quote Link to comment Share on other sites More sharing options...
Guest lambrettaman Posted February 12, 2010 Share Posted February 12, 2010 first off check the fuses mate, try the simple things first, did they both stop working at the same time? Quote Link to comment Share on other sites More sharing options...
Guest lambrettaman Posted February 12, 2010 Share Posted February 12, 2010 tried everything Quote Link to comment Share on other sites More sharing options...
Guest lambrettaman Posted February 12, 2010 Share Posted February 12, 2010 try isolater switch is not push in or as gingerman said try fuses Quote Link to comment Share on other sites More sharing options...
Guest lambrettaman Posted February 12, 2010 Share Posted February 12, 2010 tried all obvious things fuses etc Quote Link to comment Share on other sites More sharing options...
Guest lambrettaman Posted February 12, 2010 Share Posted February 12, 2010 cheers all will everything again and let u know Quote Link to comment Share on other sites More sharing options...
Guest Cabbytech Posted February 12, 2010 Share Posted February 12, 2010 I take it the windows and roof are working again now so its just that the car wont start, is it turning over on the starter ? or just not firing when turning over ? Quote Link to comment Share on other sites More sharing options...
