Guest s11pyk Posted February 11, 2010 Share Posted February 11, 2010 my mk4 efi has been sat outside untouched for about 2 weeks, went to her today and after a sluggish crank she fired into life!!!! she was quite smoky, blue and black and very tappy. i need to give the old girl some attention come pay day so what do i need? my list so far is.... engine flush coolant flush oil anti freeze tappets rocker gasket (air and fuel filter were replaced a few weeks ago) oil filter plugs while im at it the temp gauge dont work so il be replacing the sender. which one do i need? what else do i want to be doing for this health check? i want to sort the running out perfect cos the body is nearly perfect and the inside only a little damp lol its due its mot now too so im sure thats gonna throw some costs my way so the cambelts staying for now also i have a whiney noise and the engine feels loose/jumpy possibly som mounts need attention. oh and the clutch bites about 1cm upo from the floor bloody bargains for ya lol! Quote Link to comment Share on other sites More sharing options...
Guest suffolk04 Posted February 11, 2010 Share Posted February 11, 2010 just change the the oil and filter before looking at tappets, might not be anything wrong with them, and when you say engine/coolant flush, i hope you dont mean additives Quote Link to comment Share on other sites More sharing options...
Guest s11pyk Posted February 11, 2010 Share Posted February 11, 2010 whats wrong with additives? the cars clearly had a hard time engine wise. water is brown!! and the oil needs doing its black as foook! its very very tappy. like very tappy. the oil doesn't seem to get to the filler cap! Quote Link to comment Share on other sites More sharing options...
Guest suffolk04 Posted February 12, 2010 Share Posted February 12, 2010 problem with engine flushs is it turns all the old oil/dirt in your engine to sludge, which gets whipped around the pump and could cause more damage than good. same with the coolant flush things, what i did on mine when i first brought it was drain it, then fill up with cheap oil and run the car up until its red hot then drain and replace with good oil and filter Quote Link to comment Share on other sites More sharing options...
chaz Posted February 13, 2010 Share Posted February 13, 2010 problem with engine flushs is it turns all the old oil/dirt in your engine to sludge, which gets whipped around the pump and could cause more damage than good. same with the coolant flush things, what i did on mine when i first brought it was drain it, then fill up with cheap oil and run the car up until its red hot then drain and replace with good oil and filter Maybe not red hot, but definetly agree. Quote Link to comment Share on other sites More sharing options...
Guest s11pyk Posted February 13, 2010 Share Posted February 13, 2010 cool, sold on the cheap oil theory! thanks guys. what about coolant? Quote Link to comment Share on other sites More sharing options...
Guest suffolk04 Posted February 13, 2010 Share Posted February 13, 2010 with the coolant, just drain it, then use a hose pipe to back flush the system, and dont forget to flush the heater matrix seperatly Quote Link to comment Share on other sites More sharing options...
