Guest lambrettaman Posted February 10, 2010 Share Posted February 10, 2010 my battery keeps goinflat start fine go to work 10hrs battery flat jump start fine next morning fine go work same again its a new battery doin me ed in now its ground hog day everyday Quote Link to comment Share on other sites More sharing options...
Guest animal Posted February 20, 2010 Share Posted February 20, 2010 my battery keeps goinflat start fine go to work 10hrs battery flat jump start fine next morning fine go work same again its a new battery doin me ed in now its ground hog day everyday lol i'm having the same problem, once it starts it fine, will turn over ok .. leave it for a night and the next morning its as if the batterys been drained, even replaced the new battery as I thought it was a dud one but it still keeps doing it, at present the batterys on charge again and i'm trying to work out when the problem started, I'm disconecting things that I think may be the cause to see if theres any change, other then that it could be either a short circuit, a faulty alternator thats not charging the battery correctly or a badley adjusted drive belt but if I have any joy I will let you know Quote Link to comment Share on other sites More sharing options...
LeeMcCarthy Posted February 20, 2010 Share Posted February 20, 2010 Have you got any alarm fitted? Quote Link to comment Share on other sites More sharing options...
Guest wildrover Posted February 22, 2010 Share Posted February 22, 2010 (edited) lol i'm having the same problem, once it starts it fine, will turn over ok .. leave it for a night and the next morning its as if the batterys been drained, even replaced the new battery as I thought it was a dud one but it still keeps doing it, at present the batterys on charge again and i'm trying to work out when the problem started, I'm disconecting things that I think may be the cause to see if theres any change, other then that it could be either a short circuit, a faulty alternator thats not charging the battery correctly or a badley adjusted drive belt but if I have any joy I will let you know I've got the same....new battery ...leave it a day ...FLAT!!........jump start easy.....someone must have an idea? Cheers Edited February 22, 2010 by wildrover Quote Link to comment Share on other sites More sharing options...
Guest lambrettaman Posted February 24, 2010 Share Posted February 24, 2010 dissconected it driving me mad Quote Link to comment Share on other sites More sharing options...
Guest lambrettaman Posted February 24, 2010 Share Posted February 24, 2010 I've got the same....new battery ...leave it a day ...FLAT!!........jump start easy.....someone must have an idea? Cheers Quote Link to comment Share on other sites More sharing options...
Guest lambrettaman Posted February 24, 2010 Share Posted February 24, 2010 tried everything alarm fusebox doing my nut Quote Link to comment Share on other sites More sharing options...
Guest RelaxedDiver Posted February 24, 2010 Share Posted February 24, 2010 have you disconnected the radio? and take the bulb out the light in the boot as that can some times be on, even when you think the boot is closed Quote Link to comment Share on other sites More sharing options...
Guest shaun Posted February 24, 2010 Share Posted February 24, 2010 Hi mate you could try glove box to see if light is on or as other's have said the boot light....do you have a amp wired? Quote Link to comment Share on other sites More sharing options...
Guest lambrettaman Posted February 25, 2010 Share Posted February 25, 2010 Hi mate you could try glove box to see if light is on or as other's have said the boot light....do you have a amp wired? Quote Link to comment Share on other sites More sharing options...
Guest lambrettaman Posted February 25, 2010 Share Posted February 25, 2010 hi mate sorry didnt get back to you(work)tried everything still same for gods sake someone help aaaaaaaaaaaaaaaagh Quote Link to comment Share on other sites More sharing options...
Guest adamk Posted February 28, 2010 Share Posted February 28, 2010 Is you alternator good? If not, driving the car will drain the batt. and batt light on your dash may not work to tell you this. Also if your radio is wired wrong, IE, perm live and Rem mixed up, that can drain the batt too. Halford do alternators for 60 pounds, had a similar Prob on my MK4, changed batt, no good, changed alternator and sorted it. Hope that helps Quote Link to comment Share on other sites More sharing options...
