Guest pestslayer Posted December 15, 2009 Share Posted December 15, 2009 hi ,,need some help,,,1990 xr3i ragtop,wen cold no worries,,let it ticks over or is driven for a while,turn her off and retry 2 start. FLAT BATTERY SYMPTOMS,,leave 4 a while and she starts,,,, wot the hell can this be,, any ideas/// angus Quote Link to comment Share on other sites More sharing options...
badger Posted December 15, 2009 Share Posted December 15, 2009 hi ,,need some help,,,1990 xr3i ragtop,wen cold no worries,,let it ticks over or is driven for a while,turn her off and retry 2 start. FLAT BATTERY SYMPTOMS,,leave 4 a while and she starts,,,, wot the hell can this be,, any ideas/// angus hi mate when you say flat battery do you mean it just clicks if so you'll find it's a battery problem.you'll find the imobiliser has triggered because of a low battery and after left for say 30 mins etc the battery will regain on it's own and the imobiliser says its ok and lets you start the car i had this problem with my mk6 and i cured it with a new one. i hope this helps ian Quote Link to comment Share on other sites More sharing options...
Guest pestslayer Posted December 15, 2009 Share Posted December 15, 2009 (edited) hi mate when you say flat battery do you mean it just clicks if so you'll find it's a battery problem.you'll find the imobiliser has triggered because of a low battery and after left for say 30 mins etc the battery will regain on it's own and the imobiliser says its ok and lets you start the car i had this problem with my mk6 and i cured it with a new one. i hope this helps ian hi,, the engine will go 2 turn but theres not enough power,so u get 1/4 turn on starter,but no clicking idont think,i thought LAZY STARTER?? once it cools down,,it bloody starts.. Edited December 15, 2009 by pestslayer Quote Link to comment Share on other sites More sharing options...
Admin Paul Posted December 15, 2009 Admin Share Posted December 15, 2009 Sounds like your starter is getting hot, this could be your problem hense ok when cold. Quote Link to comment Share on other sites More sharing options...
Guest pestslayer Posted December 15, 2009 Share Posted December 15, 2009 (edited) Sounds like your starter is getting hot, this could be your problem hense ok when cold. thanx,but how do i fix the prob,there is a heat shield behind the starter..also if the starter is 2 blame,,wots the best 1 i can put bak on it,,diesel 1 etc???? Edited December 15, 2009 by pestslayer Quote Link to comment Share on other sites More sharing options...
Admin Paul Posted December 15, 2009 Admin Share Posted December 15, 2009 just a replacement one mate, sounds like its fauly and only breaking down when hot Quote Link to comment Share on other sites More sharing options...
Guest shaun Posted December 16, 2009 Share Posted December 16, 2009 Hi mate as paul said sounds like the starter motor is naff...same prob on mk4 escort turbo my mk4 16i cabbie done the same changed starter and solved problem Quote Link to comment Share on other sites More sharing options...
Guest pestslayer Posted December 16, 2009 Share Posted December 16, 2009 just a replacement 1 will solve the problem yeah,,is there anything else it cud be,,,i know i am being stupid,but this is a really annoying problem,,but wen its cool or cold its fine,only wen its hot. by the way THANX EVERY1 for ur help nearly 4got,, rev counter stopped workin any ideas. Quote Link to comment Share on other sites More sharing options...
badger Posted December 16, 2009 Share Posted December 16, 2009 Sounds like your starter is getting hot, this could be your problem hense ok when cold. as paul say's try a new on. Quote Link to comment Share on other sites More sharing options...
