Guest keithslater Posted November 4, 2009 Share Posted November 4, 2009 Any one know how i can get into a locked boot when the barrel has become detatched from the link rod and just pulls straight out of the boot Quote Link to comment Share on other sites More sharing options...
gingergman Posted November 5, 2009 Share Posted November 5, 2009 if the barrel pulls out of the boot cant you just remove it and stick a screwdriver or pilers into it to pull the rod? will be tricky tho. Quote Link to comment Share on other sites More sharing options...
Guest shaun Posted November 5, 2009 Share Posted November 5, 2009 Hi mate you can try like Gingergman said or you can try this way get in your back seat and bend corner back on drivers side rear seat and put your hand in to re-lease rear seat and climb in and remove rear panel and open boot from inside.DONT FORGET TO BEND SEAT BACK Hope this help's Quote Link to comment Share on other sites More sharing options...
Guest keithslater Posted November 6, 2009 Share Posted November 6, 2009 thanks for your responses to my problem It has now been solved via a hole behind the number plate Quote Link to comment Share on other sites More sharing options...
