Guest Pierce Posted October 26, 2009 Share Posted October 26, 2009 the roof doesn't seen to come all the way forward, so it doesn't reach the front screen and theres a gap round the rear quarter glass Quote Link to comment Share on other sites More sharing options...
Guest KRYSS Posted November 15, 2009 Share Posted November 15, 2009 hi i have the same problem i was told the roof could be adjusted but was,nt told how to adjust it lol hope fully someone will let us both know lol Quote Link to comment Share on other sites More sharing options...
badger Posted November 15, 2009 Share Posted November 15, 2009 hi guys i had same problem so this is what i done. all there is on a mk4 roof is 6 bolts 3 each side and a wire holding roof around body if you remove rear panels you'll see roof bolts loosen all bolts you should now be able to close the roof,lock in the front roof locators then do up the bolts on the rear frame and thats done and it should all shut i did have to adjust the glass in the front doors to seal properly as well. i hope this helps Quote Link to comment Share on other sites More sharing options...
Guest KRYSS Posted November 15, 2009 Share Posted November 15, 2009 thanks badger i will give it a try and see how it go,es kryss Quote Link to comment Share on other sites More sharing options...
