Guest dave29 Posted October 15, 2009 Share Posted October 15, 2009 hi all ive got a mk6 gti which was running fine until it decided to burst the top hose on the radiator due to been pressurised.ive replaced the top hose and toped the coolant system up but it still continues to do it but only when the temp gauge rises pretty high.the fan kicks in when the gauge is pretty high on the scale but the temp stays ok if i put the heating on full blast. i had a test done on the header tank which see,s if there are any fumes in the coolant but this came back as the head gasket had gone..... is there any chance this test could of been wrong n it,s the water pump gone? ive been quoted £350 quid to get it sorted.could this be a air lock? please help. Quote Link to comment Share on other sites More sharing options...
Guest mossop1 Posted October 15, 2009 Share Posted October 15, 2009 If its been tested at garage and they have done a block test and the fluid went from blue to yellow its gone. Quote Link to comment Share on other sites More sharing options...
Guest dave29 Posted October 15, 2009 Share Posted October 15, 2009 (edited) If its been tested at garage and they have done a block test and the fluid went from blue to yellow its gone. it had the test done but the fluid did,nt go yellow.it went green. does this mean it aint gone or its starting to go? cheers for the quick reply.i also tryed some of that k seal stuff n that did,nt work either. :@( Edited October 15, 2009 by dave29 Quote Link to comment Share on other sites More sharing options...
badger Posted October 15, 2009 Share Posted October 15, 2009 it had the test done but the fluid did,nt go yellow.it went green. does this mean it aint gone or its starting to go? cheers for the quick reply.i also tryed some of that k seal stuff n that did,nt work either. :@( its gone mate if it turned green Quote Link to comment Share on other sites More sharing options...
Guest dave29 Posted October 16, 2009 Share Posted October 16, 2009 its gone mate if it turned green cheers for the reply,s guys.i guess i was wishfull thinking about the test been wrong.is it easy to do on a zetec gti? ive been told you have to take the cams out to take the head off????? that right? also what kinda price am i looking at it i do it myself?..... parts n stuff. Quote Link to comment Share on other sites More sharing options...
Guest murcus Posted October 16, 2009 Share Posted October 16, 2009 cheers for the reply,s guys.i guess i was wishfull thinking about the test been wrong.is it easy to do on a zetec gti? ive been told you have to take the cams out to take the head off????? that right? also what kinda price am i looking at it i do it myself?..... parts n stuff. it shouldnt be too hard to do tbh its only a gasket, first you will need new belt, stretch bolts and gasket, but i would recommend doing the stem seal whilst you had the head off but its entirely up to you tools, socket set, torque wrench, valve spring compressors, oil, belt, gasket seals, and a wee bit of mechanical knowledge,, at a garage i think around 600 Quote Link to comment Share on other sites More sharing options...
Guest dave29 Posted October 16, 2009 Share Posted October 16, 2009 it shouldnt be too hard to do tbh its only a gasket, first you will need new belt, stretch bolts and gasket, but i would recommend doing the stem seal whilst you had the head off but its entirely up to you tools, socket set, torque wrench, valve spring compressors, oil, belt, gasket seals, and a wee bit of mechanical knowledge,, at a garage i think around 600 cheers for all your input guys. looks like the car is off the road as of today till its fixed. Quote Link to comment Share on other sites More sharing options...
