Guest pauls0701 Posted September 28, 2009 Share Posted September 28, 2009 on way home from work with a boot full of new spares to try and sort out handling problems the temp gauge went up in to the red. was only a very short distance from home so carryed on hen i got ho,e popped the bonnet and the fan wasnt running but also very slowly removed the rad cap and nothing but a very small psst noise so dont thgink that it is over heating and its just the temp gauge reading wrong. have looked though the site and all the other posts about gauge reading wrong seem to say that the gauge is low not high. could this also be the sender unit u/s or do you think it could be something else? wkill bring my infered temp reader home from work tomorrow and take the temp of the water Quote Link to comment Share on other sites More sharing options...
Guest Cabbytech Posted September 28, 2009 Share Posted September 28, 2009 It could deffo be the temp sensor mate, this happened on my cab recently, it went right up high a few times withina week before it packed in all together. Quote Link to comment Share on other sites More sharing options...
Guest pauls0701 Posted September 29, 2009 Share Posted September 29, 2009 cool thanks for that mate. have just phone the mrs to bring one home from work with her Quote Link to comment Share on other sites More sharing options...
badger Posted September 29, 2009 Share Posted September 29, 2009 yes fella mine read wrong that way to but changed it and all was well again Quote Link to comment Share on other sites More sharing options...
Guest pauls0701 Posted September 30, 2009 Share Posted September 30, 2009 ok changed the senser today and still doing it. what its doing is when starting from stone cold the gauge is reading half way then as it warms up it goes up in to the red have left it running and the fan is cutting in and out after about 20 mins stood running have taken temps from the top hose with an infered thermometer and its reading about 82 when fan cuts in so its defo not over heating so what else could the cause be???????? Quote Link to comment Share on other sites More sharing options...
Guest markeyboy Posted September 30, 2009 Share Posted September 30, 2009 check that the sender wire isnt shorting to earth, im pretty sure that the sensor allows more electricity to flow the warmer it gets (from live to ground) if its finding its own route other than through the sensor this would give a reading much higher than the actual Quote Link to comment Share on other sites More sharing options...
Guest pauls0701 Posted September 30, 2009 Share Posted September 30, 2009 i was thinking thats how it worked and thought that might be the problem, have checked the wiring that i can see and all looks ok think i will have to get hold of a wiring diagram and try putting new wire in Quote Link to comment Share on other sites More sharing options...
Guest markeyboy Posted September 30, 2009 Share Posted September 30, 2009 have you tried disconnecting the sensor and running the car to see what the guage reads, with it disconnected the gauge should not read anything, then short it to earth (stick another wire in the end and earth that) and it should read the max temp, if this works you may have the incorrect temp sensor, if it dont its probably somthing wrong with the gauge itself, (which i dont know anything about) Quote Link to comment Share on other sites More sharing options...
Guest pauls0701 Posted September 30, 2009 Share Posted September 30, 2009 yes tryed disconecting the senser and gauge still reads half way. looks like its something im going to have to put up with, will soon know if it boils by the steam coming out the bonnet lol Quote Link to comment Share on other sites More sharing options...
