Guest tacha_maree Posted September 4, 2009 Share Posted September 4, 2009 hello my wise and wonderful friends i really could do with some help. My new cabby is fitted with a orion si 130 zetec engine its all running etc but the alternator isnt fitted thus battery isnt charging but importantly my water pump isnt being driven. it came with a CVH and a zetec alternator which one should i use?? also i have no idea how or where to mount it or what belt will fit. theres a few of you with zetec conversions so im sure someone can help me. please any help would be very much appreciated. thanks Quote Link to comment Share on other sites More sharing options...
Guest markeyboy Posted September 4, 2009 Share Posted September 4, 2009 My link have a look on here tash Quote Link to comment Share on other sites More sharing options...
badger Posted September 4, 2009 Share Posted September 4, 2009 (edited) i have mine mounted at the bottom where it normally is but you do need a smaller belt i have the zetec alternator and i'll look tomorrow and find you the belt size i use or you can place it into place then tie a piece of string around all 3 pullys and then measure the lengh of string and this will give you your belt size. you might also need to alter your wiring theres still only 2 connections but with different fitments on. i also just use the 3 pullys (crankshaft/waterpump and alternator) Edited September 4, 2009 by badger Quote Link to comment Share on other sites More sharing options...
Guest tacha_maree Posted September 5, 2009 Share Posted September 5, 2009 thanks guys got it sorted cheers for all your help Quote Link to comment Share on other sites More sharing options...
