Guest tenbyford Posted August 28, 2009 Share Posted August 28, 2009 1989 Cabriolet perfect but for an annoying issue with the starter. Fine when cold but when warm the starter is very slow, I have changed the starter 3 times with quality recons and even invested in a heat shield. I had to wait 30 minutes the other day outside a shop for it to cool before stating was enabled. Quote Link to comment Share on other sites More sharing options...
Guest bobatporty Posted August 28, 2009 Share Posted August 28, 2009 as you must have ruled out starter problems check out your wiring mate Quote Link to comment Share on other sites More sharing options...
RobMk4TwinCarb Posted September 1, 2009 Share Posted September 1, 2009 Check your coil, if yours is a model with one, they can overheat and stop the car from starting until they are cool again. Quote Link to comment Share on other sites More sharing options...
Guest richie29gt Posted September 15, 2009 Share Posted September 15, 2009 i have the same issue on a 90 xr3i and im thinking its downs to the rad fan taking all the power u need to start as i have found out alot recently its a pain when u get to a set of lights and the car stalls and the damn thing wont start grrrrr from behind and a whole lot of abuse 2 i have even tried with a bigger battery to up the crankage amps but still the same prob fords u gota love them :icon_salut_gb: Quote Link to comment Share on other sites More sharing options...
iansoutham Posted October 23, 2009 Share Posted October 23, 2009 Both of you need to check your earth connections from the battery to the engine and from the battery to the shell. Also, check the power lead from the battery to the stater as this is almost certainly where your problem is. Quote Link to comment Share on other sites More sharing options...
Admin Paul Posted October 23, 2009 Admin Share Posted October 23, 2009 Have to agree with Ian, start at the basics first. Quote Link to comment Share on other sites More sharing options...
