Guest theonlynuttytart Posted August 22, 2009 Share Posted August 22, 2009 hi need some advice! have a n reg 1.8si cabby, recently had problems with it starting, turn key fuel pump isnt kicking in. auto electrician thinks it may need the circuit board replacing, somewhere behind the fuse box? im trying to keep costs down and trying to locate the part myself, but have no idea how to get part number or just ask for the circuit board? thanks karen Quote Link to comment Share on other sites More sharing options...
Guest markeyboy Posted August 22, 2009 Share Posted August 22, 2009 hi, the most cost efective way would be to replace the whole fuseboard with (if possiable) the same spec of cabby as ur one (try ebay or ur local scrappy) the number should be on the side/top of the fuse box Quote Link to comment Share on other sites More sharing options...
allblue Posted August 22, 2009 Share Posted August 22, 2009 Hiya Assuming it is your fusebox check out my Mk6 fusebox post in the General Discussion. Does any of your other elec items work? Such as headlights, indicators, heaters? With fuseboxes usually these go first and then eventually the car fails to start. Quote Link to comment Share on other sites More sharing options...
Escort Cabriolet Club Posted August 23, 2009 Share Posted August 23, 2009 Karen this is the Topic: http://www.escortcabrioletclub.co.uk/forums/index.php?showtopic=18608&pid=144707&st=0entry144707 Quote Link to comment Share on other sites More sharing options...
