Guest PhilBcab Posted August 12, 2009 Share Posted August 12, 2009 right i know of the adaptor to get, bt i remember in the maveric the spkrs seem like its breakin up as in too much power goin through them, we are using a sony xplod sterio with 45w output so would this overload the amp........ if so what wires are what.... for a bit of diy speaker rewiring as ive got everything if i need to go that direction Quote Link to comment Share on other sites More sharing options...
Escort Cabriolet Club Posted August 14, 2009 Share Posted August 14, 2009 After Market Speakers can somtimes pop Factory speakers, for best results upgrade them !!! Quote Link to comment Share on other sites More sharing options...
Guest PhilBcab Posted August 14, 2009 Share Posted August 14, 2009 What I meant was charlzy is it worth buying the adaptor to trick the ford 2007 external amp whilst using the Sony sterio or should I bypass the whole system with new wires and rewire the power harness to suit? Quote Link to comment Share on other sites More sharing options...
Escort Cabriolet Club Posted August 14, 2009 Share Posted August 14, 2009 I would by pass the amp as the head unit is an amp too so two in line can't be good !!! Quote Link to comment Share on other sites More sharing options...
Guest PhilBcab Posted August 14, 2009 Share Posted August 14, 2009 routes out haynes/ finds his speaker wire Quote Link to comment Share on other sites More sharing options...
Guest Eggsy Posted August 14, 2009 Share Posted August 14, 2009 What I meant was charlzy is it worth buying the adaptor to trickthe ford 2007 external amp whilst using the Sony sterio or should I bypass the whole system with new wires and rewire the power harness to suit? Be honest m8 your sony stereo's built in amp will be more powerfull than the standard ford anyway!! Quote Link to comment Share on other sites More sharing options...
Guest PhilBcab Posted August 14, 2009 Share Posted August 14, 2009 i know but the ford amp isin between the new sterio and the speakers soieither risk connecting with smart lead and blowin th lot or bullet connect new wires direct to speakers so ill do the latter Quote Link to comment Share on other sites More sharing options...
