Guest pjw Posted July 9, 2009 Share Posted July 9, 2009 i just got my xr3i and i think its been stood for a while - i thought the thermostat was stuck open as it was constantly running at about 1/4. the original thermo was knackered and so was the rubber seal below it, presumably letting water through. i just replaced the thermostat and coolant, and it seems to be the same if not only marginally warmer. runs about 1/4 when driving then when idling goes no higher than 1/3 and then the fans come in and it sits there. could the gauge be bust or the CTS gone? Quote Link to comment Share on other sites More sharing options...
Guest Ady Posted July 9, 2009 Share Posted July 9, 2009 how old is the rad m8? Quote Link to comment Share on other sites More sharing options...
ianxr3i Posted July 9, 2009 Share Posted July 9, 2009 My temp gauge runs at the same as you gauge does & I have checked my coolant system, there is no probs with my system. Quote Link to comment Share on other sites More sharing options...
Guest pjw Posted July 9, 2009 Share Posted July 9, 2009 radiator is nine months old. glad its not just mine, i was just fretting that usually with efi engines if its always running cold or the cts is bust then it runs rich, leading to really bad fuel consumption. flushed it out and the coolant is nice and clean now too, you should have seen the crap that came out. Quote Link to comment Share on other sites More sharing options...
chaz Posted July 9, 2009 Share Posted July 9, 2009 (edited) My temp also stops about quarter up the gauge but I do have the fan switch operating at 82 fahrenite to help it keep cool since it is very hot over here. I also flush the radiator once every other year on the cab. Edited July 9, 2009 by chaz Quote Link to comment Share on other sites More sharing options...
