Guest MadCow Posted June 11, 2009 Share Posted June 11, 2009 Hi peeps, My cars been giving me constant electrical problems, and this morning I jumped in her, shes winding over, the fuel gauge reads over 1/4 tank, the fuel pump kiks in for a couple of seconds when I switch on ignition, checked fuel cut off, but she just keeps winding and won't start, please is there any one thats had this problem? I've spent so much money on this car in the last few months, and this feels like the final straw, any help would be received with great thanks. Oh and its a mk5 Cabby xr3i (105ps) Thanks again, Mel. Quote Link to comment Share on other sites More sharing options...
RobMk4TwinCarb Posted June 11, 2009 Share Posted June 11, 2009 If it isn't firing a possible cause could be the crank position sensor, if that isn't on properly or is broken then you wont get any spark. Im only assuming your engine would have one as I have never owned a mk5 but yea, could be your problem. Quote Link to comment Share on other sites More sharing options...
Guest hoochydady Posted June 11, 2009 Share Posted June 11, 2009 hi make sure your getting a spark pull a sparl plug lead off and ad a old plug that u know to be good and see if its sparking Quote Link to comment Share on other sites More sharing options...
Guest busadaddy Posted June 11, 2009 Share Posted June 11, 2009 yes as above pull a plug check se if your getting a spark Quote Link to comment Share on other sites More sharing options...
Guest MadCow Posted June 12, 2009 Share Posted June 12, 2009 Thanks guys, just checked spark, theres no spark, but there is power going into the coilpack, the middle out of the three wires is live. Any ideas? really stuck on this one. Cheers, Mel. Quote Link to comment Share on other sites More sharing options...
badger Posted June 12, 2009 Share Posted June 12, 2009 Thanks guys, just checked spark, theres no spark, but there is power going into the coilpack, the middle out of the three wires is live. Any ideas? really stuck on this one. Cheers, Mel. the coil packs are known to break down from time to time you could try that. Quote Link to comment Share on other sites More sharing options...
Guest tacha_maree Posted June 14, 2009 Share Posted June 14, 2009 could be your edis moduel. ive got a mk4 efi which did the same thing... was the cps and the edis moduel Quote Link to comment Share on other sites More sharing options...
Guest matt-the-dj Posted June 16, 2009 Share Posted June 16, 2009 crank case sensor, same thing happened to mine. Quote Link to comment Share on other sites More sharing options...
