Guest kevspireites Posted June 2, 2009 Share Posted June 2, 2009 (edited) got a mk5b 1.8si all is fine started first time in the morning, went for a drive but wouldn't start after we'd stopped. all sounded normal just no fire, started after about 10 mins done it a few times, same again today. any ideas guys? thanks in advance Edited June 2, 2009 by kevspireites Quote Link to comment Share on other sites More sharing options...
Guest stivy Posted June 4, 2009 Share Posted June 4, 2009 got a mk5b 1.8si all is fine started first time in the morning, went for a drive but wouldn't start after we'd stopped. all sounded normal just no fire, started after about 10 mins done it a few times, same again today. any ideas guys? thanks in advance had the same probs with my mk4 3i, do u have a toad alarm fitted. i think the problem i have is with that. i try too start it and it wont fire, but if i get out with the keys and start again, it fires up no problems. but it only happens on a very warm day. Quote Link to comment Share on other sites More sharing options...
Guest kevspireites Posted June 5, 2009 Share Posted June 5, 2009 not got an alarm have been told it might be lambda sensor but not sure Quote Link to comment Share on other sites More sharing options...
Guest matt-the-dj Posted June 5, 2009 Share Posted June 5, 2009 had a similar one on my mk5 dash, if i remember correctly it was a dirty crankcase sensor........not 100% sure but worth a look Quote Link to comment Share on other sites More sharing options...
RScab Posted June 6, 2009 Share Posted June 6, 2009 Does your starter motor have a heat shield fitted? Had the same problem on a mondeo, Starter was cooking when the engine was hot. Fitted a heat shield and was fine after that, Worth a try. Quote Link to comment Share on other sites More sharing options...
Guest TSR157 Posted June 6, 2009 Share Posted June 6, 2009 got a mk5b 1.8si all is fine started first time in the morning, went for a drive but wouldn't start after we'd stopped. all sounded normal just no fire, started after about 10 mins done it a few times, same again today. any ideas guys? thanks in advance sorry m8 this ones got me Quote Link to comment Share on other sites More sharing options...
Guest kevspireites Posted June 15, 2009 Share Posted June 15, 2009 well heres an update changed crank sensor, coil pack new plugs leads etc wouldn't start again after about an hours run left it 10 mins started fine but i had no lights,indicators,wipers,heaters,windows etc more or less nothing electrical got home and parked her up. this morning went out and the car wouldn't start, so decided to compare with bro in laws as its the same thinking surley this is an electrical problem, we found a few relay's less in my fuse box so decided to put them in mine out of his and hey presto it started only to find out his still did too, so took the fuses back out and the car still started at this time my head is ready to explode as this makes no sense when it wouldn't start prior to putting the relays in am totaly stumped now so any help would be great although i have a feeling it will baffle you all aswell Quote Link to comment Share on other sites More sharing options...
Guest charlie74 Posted June 15, 2009 Share Posted June 15, 2009 might be the fuse box itself, any signs of corrosion? Quote Link to comment Share on other sites More sharing options...
Guest kevspireites Posted June 15, 2009 Share Posted June 15, 2009 no corrosion at all had it out and all seems ok Quote Link to comment Share on other sites More sharing options...
