Guest ford Posted May 21, 2009 Share Posted May 21, 2009 (edited) Hei guys!I need your help again I had a set of amps and speakers and tried yesterday to fit it with the new Blaupunkt MP66 i bought that i should say is great!!!The bad thing is that even i connected everything(i think correctly) i dont have sound. The bad thing is that the blaupunkt doesnt have the inputs on it but have a "loom" that connects to it that has 4 inputs for the amp and a small cable that says 12V. The loom is the one with the yellow plug on the left of the picture and the cable that says 12V is the orange one in that loom At first i thought this was the remote but it says 12V from the amp. What should i connect there? For know i connected the remote cable there because i thought that was but i think i am wrong... Any help guys?I am desperate!!! Edited May 21, 2009 by ford Quote Link to comment Share on other sites More sharing options...
RobMk4TwinCarb Posted May 22, 2009 Share Posted May 22, 2009 (edited) I can't say for sure but usually the remote comes from your headunit and you wire a seperate fused 12v straight from the battery to your amp, also the red and white would be L+R channel audio, yellow is usually video and the black im not sure. Hope this has been at least a little help. Edited May 22, 2009 by RobMk4TwinCarb Quote Link to comment Share on other sites More sharing options...
Guest ford Posted May 22, 2009 Share Posted May 22, 2009 Thanks for the reply my friend I connected the first amp this morning and it sounds great !!! Quote Link to comment Share on other sites More sharing options...
