1.6i Mkiii 1985 Cab
Guest Keyper
Guest Keyper
wonder if any1 can give me a little insight into the workings of the injection system
i've brought my car home (towed) but i cant get her started
its deffo a fuel problem as my spark plugs are dry as a bone. however my knowledge of the fuel injection is erm headscratchin..!
i have fuel leaving the injection system to 2 points which are to the cold start & the warm up regulator but i'm not getting any fuel fed to the main jets.
i was wondering weather it could be a lazy fuel pump or a blocked fuel filter?
any help appreciated
cheers
John
Guest Keyper
i would check the metering head its prob stuck
cheers for the reply m8
stuck as in blocked or does it have a valve of some sort that regulates the fuel timing into the inlet manifold. I'm not sure what to look for if i split it
Guest busadaddy
where all the pipes come from(red ones)there is a black round dome type thing take that off and lift it up or down and try and start it
Guest Keyper
nice 1 m8, i'll have a look at that
  • 3 weeks later...
