Guest skullman Posted February 15, 2009 Share Posted February 15, 2009 when i try to start car there is no spark, i have a mk 4 efi cabriolet. any ideas on why this is happening would be greatly appreciated. thank you Link to comment Share on other sites More sharing options...
Guest spenny Posted February 16, 2009 Share Posted February 16, 2009 could be the coil or ignition amplifire on the dizzy.. hope this helps Link to comment Share on other sites More sharing options...
Vincygav Posted February 16, 2009 Share Posted February 16, 2009 Or could be the spark plugs Link to comment Share on other sites More sharing options...
Guest skullman Posted February 17, 2009 Share Posted February 17, 2009 could be the coil or ignition amplifire on the dizzy.. hope this helps thanks will try this at weekend Link to comment Share on other sites More sharing options...
Guest danieltovey Posted February 20, 2009 Share Posted February 20, 2009 thanks will try this at weekend hello mate, i have the same problem, no spark from the coil. I have changed the coil, i have changed the distributor, i have changed the ecu's (both fuel and igntion), i have tested the coil by linking the negative to the battery and have still had no joy. My cabbie is a mk4 g reg escort, but i have placed in a full 90 spec turbo loom, full mk3 s1 engine and gearbox, with s2 fuel injection setup. I have been out there trying to get it started now for a couple of weeks with no joy. Let me know if you have any luk as i may have the same problem as you. Cheers Link to comment Share on other sites More sharing options...
