Ke-jetronic Fuel Pressure Regulator
Guest mac
hi could some one help as im abit stuck im currently building my escort rs cabriolet and i have just fitted a fuel meetering unit but have noticed that the fuel pressure regulater which is connected to the metering unit has a small pipe at one end ,looks like there should be a vacume hose conncted to it can any one help??
hi fella
most fuel regulators are feed a vacum pipe from the inlet manifold
ok cheers for that , been through the book on it and a few web sites but cant find anything about this pipe on the end it tells you about everything else but that hence why i wasnt to sure if it needed a vacume hose or not.
