Guest doobieduck Posted November 3, 2008 Share Posted November 3, 2008 just wondering if anyone could help me? looking at up-grading front and rear.can anyone tell me what size i will be lookin for? went down to local motorworld,went in ask the guy if he had a book to tell me what im looking for,guy came back after 5 mins said we did have one buts someone stole it (lol) so he went away ask someone else came back and said sorry cant help you......thought well thats good Link to comment Share on other sites More sharing options...
Guest markeyboy Posted November 3, 2008 Share Posted November 3, 2008 not sure on what size they are, there kinda 2 in one have a look at this link http://www.escortevolution.co.uk/howto/view.php?id=10 this is what iv done on mine, got 165mm blaupunkt in the front now, sound dood and its pretty easy to do too Link to comment Share on other sites More sharing options...
Guest doobieduck Posted November 3, 2008 Share Posted November 3, 2008 cheers markeyboy ive been in the how to's there aswell and didnt show me that much.well prob coz thats me a full member now it shows.all i need to do is sort the back now and we are sorted Link to comment Share on other sites More sharing options...
Guest markeyboy Posted November 3, 2008 Share Posted November 3, 2008 the rears are a simular design to the front speakers but i dont know what size they are, ya gota take the whole rear card off to get at them too Link to comment Share on other sites More sharing options...
Escort Cabriolet Club Posted November 4, 2008 Share Posted November 4, 2008 cheers markeyboy ive been in the how to's there aswell and didnt show me that much.well prob coz thats me a full member now it shows.all i need to do is sort the back now and we are sorted With you there mate, there guides are pretty vauge at best, I still need to up-grade mine but short on coin at the mo, but when I do them a guide will follow !!! Link to comment Share on other sites More sharing options...
Guest markeyboy Posted November 4, 2008 Share Posted November 4, 2008 here goes you need to get yourself a set of these - can usually find them on ebay and a set of 165mm speakers in my case these you need to remove the door card theres a screw inside the door opening leaver, one in the handle that you use to shut the door with (when inside) one (maby 2) in the door pocket and a few smaller ones around the side and underneath the door card lift the door card upwards to unclip it from the top clips. remove the old speaker it should then look somthing like this you then need to attach the new speaker converter plates, (i think this is done by either drilling and self tappers or using existing holes) connect the wires up to the speaker, i chopped the ford plug off the end and had mine going through a crossover unit, you can crimp the correct fittings on the end of the ford wiring and go from there tho ( maplins/halfords are probably the best place to get them from - they do tend to be a bit procy from them tho) you then need to mount the speaker (i sued the 4 pre-drilled holes on the new plate and used self tappers) this is it fitted refit the door card "fitting is the reverse of removal" - Haynes make sure you get the door card in the top clips correctly, can make the door card ftay a bit if ya mess it up so tke ur time and do it carefully once done turn it up LOUD!!!!!! Link to comment Share on other sites More sharing options...
Escort Cabriolet Club Posted November 4, 2008 Share Posted November 4, 2008 Nice one mate !!! Link to comment Share on other sites More sharing options...
