Guest jonnyc Posted August 12, 2008 Share Posted August 12, 2008 (edited) Hi all what was meant to be an easy rear wheel cylinder change today went a bit wrong. Fitted the cylinder in fine but on take out the brake pipe that goes into the wheel cylinder it decided to brake i think the pipe corroded itself onto the nut!!! So does anyone have a spare right hand side rear hard brake pipe lying around....the one that goes around the suspension leg and fixes into the rubber flexible pipe before the drum? See Picture below for which is needed as you can see in the picture its temporarily covered with a yellow dust cover. Many Thanks Jonathan Edited August 12, 2008 by jonnyc Link to comment Share on other sites More sharing options...
escortcabrioletclub Posted August 12, 2008 Share Posted August 12, 2008 most good car speares shops will make one for you if not take what youhave ie with both ends to a car garage and should makeonefor you to 10-20 quid pitty you not close as i could have made it Link to comment Share on other sites More sharing options...
Guest 6tracy9 Posted August 12, 2008 Share Posted August 12, 2008 As Tony says these things can be easily made by any good motor factors, Link to comment Share on other sites More sharing options...
Guest jonnyc Posted August 12, 2008 Share Posted August 12, 2008 Ye will have to look into that anyone breaking a mk4 cab? Link to comment Share on other sites More sharing options...
Guest marcus Posted August 12, 2008 Share Posted August 12, 2008 Do motor factors still make them for customers ? thought this was now illegal for them to make braking hyd lines in copper or similar, or am i wrong, not to say that they dont sell the tubing and ends seperatly. Adios Steve. Link to comment Share on other sites More sharing options...
Guest Themarshall01 Posted August 29, 2008 Share Posted August 29, 2008 Do motor factors still make them for customers ? thought this was now illegal for them to make braking hyd lines in copper or similar, or am i wrong, not to say that they dont sell the tubing and ends seperatly. Adios Steve. Recently replaced mine and had new ones made by local motor spares shop, I just had to put bends in. Dont quote me but I dont think it is illegal as all the motor spares near me make them. Link to comment Share on other sites More sharing options...
Guest frankieC Posted August 29, 2008 Share Posted August 29, 2008 Ye will have to look into that anyone breaking a mk4 cab? i am breaking a c reg xr3i cab if it is the same i have one i could post to you Link to comment Share on other sites More sharing options...
