Guest Kyle Posted August 12, 2008 Share Posted August 12, 2008 Hi All, This may be a bit of a noob question but in the back of my MK6 I have speaker casing on either side above the window winder. I can't seem to get the casing off to put a speaker in though. Is there a screw I need to undo? Do I just pull it off? (Have pulled it quite hard but I'm scared I'll break it.) Thanks. Link to comment Share on other sites More sharing options...
Guest Dazzaas Posted August 12, 2008 Share Posted August 12, 2008 Hi All, This may be a bit of a noob question but in the back of my MK6 I have speaker casing on either side above the window winder. I can't seem to get the casing off to put a speaker in though. Is there a screw I need to undo? Do I just pull it off? (Have pulled it quite hard but I'm scared I'll break it.) Thanks. if its same as mk5 you have to remove whole panel grill not removable good luck dazza Link to comment Share on other sites More sharing options...
Escort Cabriolet Club Posted August 12, 2008 Share Posted August 12, 2008 Its not hard to do mate, just time consuming, be ideal to have the weather too, remove the rear lower bench, there are a couple of screws holding the card in down the side of the door apature, then it needs a good tug as there clipped in, always remove the winder first though, any probs let us all know and we will try and help !!! Link to comment Share on other sites More sharing options...
Guest 6tracy9 Posted August 12, 2008 Share Posted August 12, 2008 Be firm but gentle when you have removed the screws - sometimes the clips have a tendancy to break! Link to comment Share on other sites More sharing options...
Guest rambo Posted October 16, 2008 Share Posted October 16, 2008 i cant evan get the winders off, i can strip a engine but when it come's to window winders i walk away lol Link to comment Share on other sites More sharing options...
Escort Cabriolet Club Posted October 17, 2008 Share Posted October 17, 2008 There is a sping circlip holding them on mate, a small flat head scredriver will get it off, just locate on of the 2 ends and release it !!! Link to comment Share on other sites More sharing options...
Guest markeyboy Posted October 17, 2008 Share Posted October 17, 2008 there is a little trick that ya can do with a bit of rag, ya tuck it behind the winder (where the clip is) and pull it back and thorth kinda like the old shoe shine ploke would do, it catches the clip and as you pull it it pings off, then ya gota find the clip - that can travel far Link to comment Share on other sites More sharing options...
