A Little Help
Guest PeeWee
Guest PeeWee
Now i have fitted amps before to various escorts taking the power lead from the battery correctly along the passenger floor cowling tray into the boot but obviously now the cab is a little different at the point i want to enter the boot.
On the mk5b 5 door all i did was loosen the trimming in the corner of the rear bench letting me feed the wire nicely in.
How do i do this on the cabriolet model please. :wacko:
Guest fatboy billy
i dont have a mk5/6 but ive stripped the interior out of one and in my mk4 ive done it the same as if it was a tin top
I fed my Power Cable on the N/S as theres a nice space between the bulkhead that Eggsy showed me and the RCA leads down the O/S, I put them under the plactic trim along the base of the sill which is held in by plastic screws and fed them under and behind the rear quater cards, then under the boot carpet, if your stuck bud me and Daz will help you out !!! :biggrin:
Guest 6tracy9
mine goes under the back seat rather than through the rear door cards and then into the boot that way, My amp is fixed onto the back of my rear seat so it made it a lot easier for me!
Guest PeeWee
You free today as I was going to go and give Daz a slap !!! :biggrin:
HaHa, unfortunatly not mate im in work atm then busy later, wont be doing any car related fun till the weekend.
Mind you i said that last week too but the sun prised me into wales for a nice cool roofless drive lol.
