Mk4 Head Unit Wiring Headache
Guest amedcalf
Guest amedcalf
Hi all
Please help me. On my Mk4 cab some nice person has cut off the connectors for my power supply and speakers :mad: on my head unit. I'm going to have to look at getting some more standard ford male connectors.
Would someone be so kind as to advise me to wich order I will have to put them in when I have the connectors.
The wires colours are as follows :-
Red
Yellow
Brown
Blue
Grey/Yellow
Red/White
Thicker Brown.
Please could I have a pic. :laugh:
Thanks
Allan
Allan
Guest eddie
allan mate your best bet is go to the car scrap yard find an old escort and cut the radio (head unit) plug off then just attach colour to colour from the plug to your car wires if you cannot find one or need further help let me know and i will take mine out and have a look for you as mine had been cut and i had to attach a new wiring block the same as you are having to do.just ler me no if you need further help allan mate.
Guest smoothy582
hi allan this is from what i can remember (been a long time since i used standard wiring)
first off check for some more wires as speaker wires are missing and i think some one might have had an amp fitted as the only blue wire should be for an amp
hope this helps
Red- battery
Yellow- acc switch
Brown
Blue
Grey/Yellow
Red/White- not used
Thicker Brown- earth
black/grey- aerial
Guest amedcalf
Thanks eddie. I'll have a look at my local scappy tomoz and see if they can help. If not i'll let you know.
Smoothie. Thanks for help, havnt got a clue what the other three do, just need to get myself some blocks now. oh joy.
Guest suffolk04
had this problem on my old mk4, some left wires hanging and just tapped them up.
yellow + switched
red + permanent
brown earth
red with white tracer two electric aerial
grey with yellow tracer illumination wire (dont know what that one is, maybe back light on the old stereos)
when you done that, should just be the speaker wires left, get a 9v square battery, and put the wires on both sides. you get a speaker crackle, this helps if you got one of them speaker selector in the dash, or for the headunit speaker balance.
Guest amedcalf
Thanks for everyones help. I've now managed to ge tthe stereo sorted.
Cheers all
Allan
Guest eddie
hello allan mate glad you got the stereo sorted makes the car a much nicer place when its got some tunes in it well done mate now enjoy the fruits of your hard work mate.
