badger Posted June 2, 2008 Share Posted June 2, 2008 right i'm doing my zetec conversion and have fitted a mk4 efi loom which myself and tony striped out of a scraper. someone had raided all the relays from under the dash and i would like to know if you can help me to indentify them and also if you have codes for relays so i can purchase some new ones. under the dash in drivers footwell are 5 relay holders colour coded as well there is a . yellow red green blue and light blue which i know is heated front screen. can you tell me what others do. Link to comment Share on other sites More sharing options...
badger Posted June 3, 2008 Author Share Posted June 3, 2008 come on gang help me out will ya Link to comment Share on other sites More sharing options...
badger Posted June 8, 2008 Author Share Posted June 8, 2008 just a quick update i've looked again and the red one is purplie-pinkish and i belive thats the fuel pump relay the green i think is abs but still not sure on yellow or blue so if you know TELL ME please. Link to comment Share on other sites More sharing options...
Guest SiV6Si Posted June 9, 2008 Share Posted June 9, 2008 MK 4 Escort never had relays ( excpet fuel pump relay ) under the dash. MK 5 / Mk 6 had relays under the dash. So if your fuse box is from the Mk 5 or MK 6 then the Relays are as follows. Pre 96 Post 96 YELLOW Interior Light Delay (lge) Interior light delay (sml) Starter inhibitor PURPLE Fuel Pump Relay ABS ( more violet than purple ) LIGHT GREEN CFI Delay relay DARK GREEN ABS System ABS BLUE Headlight Washer A/C Location for each relay. PRE 96 R1 GREY Heated Screen R2 RED Windscreen Intermittant relay R3 GREY Heated rear screen R4 DARK GREEN ABS (system) R5 VIOLET ABS (pump) R6 WHITE / YELLOW Main beam R7 ORANGE Rear wiper intermittant control R8 GREEN / RED/ YELLOW CFI Delay relay, EFI Supply relay or EEC IV supply relay R9 BROWN Fuel Pump R10 BROWN Magnetic Clutch ( A/C ) R11 GREEN A/C R12 BROWN Engine Running R13 - R15 Not used R16 VIOLET Fuel pump R17 YELLOW Interior light delay R18 GREEN Electric Windows R19 GREY Rear Fog Light (module) R20 Spare R21 -/WHITE BusBar - Front Foglights Module R22 BLUE Head light Washer R23 WHITE Dip Beam R24 - / RED / YELLOW Busbar / Auto Trans / Alarm R25 WHITE Front fog lights R26 BLACK Steering lock / starter switch Location for each relay. POST 96 R1 BLACK Steering Lock R2 BROWN Fuel Inj / Engine Managment R3 BROWN Fuel Pump R4 BROWN Magnetic Clutch R5 GREY Heat Rear window Timer R6 RED Windscreen Wiper control R7 ORANGE Rear Wiper control R8 BROWN Dip Beam R9 BROWN Main Beam R10 BROWN Main Beam (RHD ONLY ) R11 YELLOW Interior light delay R12 GREY Rear Fog Lights R13 YELLOW Starter Inhibitor R14 WHITE Front Fog light control R15 BROWN Front Fog light Supply R16 BLUE Headlight Washer system R17 BLUE A/C System R18 R19 R20 R21 VIOLET ABS System R22 DARK GREEN ABS System As for part numbers, i'm sorry but i don't know them. But i'l try and find out for you. Link to comment Share on other sites More sharing options...
badger Posted June 9, 2008 Author Share Posted June 9, 2008 well i am lost as i've just fitted a mk4 efi loom and the relays are under dash as above so i don't think your quite right, but i do appriceate the help,many thanks for that. Link to comment Share on other sites More sharing options...
