Guest daKlone Posted May 17, 2008 Share Posted May 17, 2008 As title really - I can't see how you get the trim off from around the footwell speakers. Can anyone tell me how to do it without breaking them? Link to comment Share on other sites More sharing options...
Chris Posted May 17, 2008 Share Posted May 17, 2008 Take a torx head socket and loosen the lower dasboard screw on the inside door, then unscrew the inner cill trim.. then gentle slide the cover out..you may need to hold the dash up out the way slighty Link to comment Share on other sites More sharing options...
Guest DJB29 Posted May 17, 2008 Share Posted May 17, 2008 As title really - I can't see how you get the trim off from around the footwell speakers. Can anyone tell me how to do it without breaking them? unskrew the two allen key bolts for the dashboard it gives a bit more play to pull them out. they are a tight fit so you have got to give quite a tug on them to get the speaker pods out, and a bit hard to get them back in Link to comment Share on other sites More sharing options...
Guest daKlone Posted May 17, 2008 Share Posted May 17, 2008 Thanks chaps - I had already undone both the dashboard side bolts and one at the top (above the instrument panel) along with removing the sill trim, but it still seemed like the trim panel wants to break before it will come out. I'll give it another try though :msg3: Link to comment Share on other sites More sharing options...
