Guest J16006 Posted May 15, 2008 Share Posted May 15, 2008 Hi guys - my first post ...... so here goes! I'm trying to get a 16v cabriolet Si back on the road. .... Its been garaged for about 8 years and hasn't been moved. It has been started very occasionally - but the last time was about 18 months ago. I've now got it firing and running if you squirt some fuel into the cylinders, but I reckon the fuel pump isn't running as it won't keep on running. It has the fuel pump buried in the tank, and it looks as though there has been a problem with the pump/sender connector in the past as the +ve to the pump (bk/red wire) has a joint in it .... with a wire bypassing the pin in the plug and disappearing straight into the tank through a hole drilled in the plastic connector! ........ Yeeeee Haaaa ! What I'm after is the pinout wiring for this connector. I've got two brown wires, a brown/black stripe, a brown/green stripe and the bk/red. As the fuel guage doesn't work either I reckon either the connector is miswired, or the sender and pump is dead .... My Haynes book doesn't give this detail, so can anyone help ?? I want to check everything I can before I drop the tank out this weekend .... Andy Link to comment Share on other sites More sharing options...
Guest ste Posted May 15, 2008 Share Posted May 15, 2008 hopefully this will help you, but first have you tried the fuel pump reset switch in the drivers footwell. your 2 brown wires are earths, brown and black is sender unit, brown and green fuel pump, black and red goes to the ecu. i have attached diagram so you can look for yourself W5933040.pdf Link to comment Share on other sites More sharing options...
Guest J16006 Posted May 17, 2008 Share Posted May 17, 2008 thanks for the info. Big help. I ended up having to drop the tank anyway, to get the pump assy out. Pump motor seized ..... and 5 pin connector badly corroded. Anyone got a pump assembly for a Mk5 escort ? Andy Link to comment Share on other sites More sharing options...
Vincygav Posted May 20, 2008 Share Posted May 20, 2008 Check ebay, they do come up from time to time Link to comment Share on other sites More sharing options...
