Guest djadamx Posted April 26, 2008 Share Posted April 26, 2008 When i put the heater on it only blows out cold air and the swith on the dash only works on speed no.2.Any ideas? Thanks Link to comment Share on other sites More sharing options...
Guest shaunie Posted April 26, 2008 Share Posted April 26, 2008 When i put the heater on it only blows out cold air and the swith on the dash only works on speed no.2.Any ideas? Thanks 1 it sounds like you eith have air lock in your system or no water in res i would say or i'm not sure but might be thermostat as for only working on number 2 i would say that is your switch itself Link to comment Share on other sites More sharing options...
Guest ANDYA Posted April 26, 2008 Share Posted April 26, 2008 Sounds like a water problem, check it out immediately. Andy Link to comment Share on other sites More sharing options...
Vincygav Posted May 6, 2008 Share Posted May 6, 2008 no heat could mean either the cable is broken to the matrix, or the heater matrix is gone or blocked up with crap. As for the fan not working on position 1, this is the resistor block normally located on top of the blower motor under the scuttle panel in the bonnet area. Link to comment Share on other sites More sharing options...
