Admin Paul Posted April 7, 2008 Admin Share Posted April 7, 2008 Where is the battery light fed from on a MK4? Paul Link to comment Share on other sites More sharing options...
escortcabrioletclub Posted April 7, 2008 Share Posted April 7, 2008 from the battery sorry i really could not help myself ................. as taz said its the blue pill sorry wire Link to comment Share on other sites More sharing options...
Admin Paul Posted April 7, 2008 Author Admin Share Posted April 7, 2008 The blue wire that pushes on the the alternator? on the little peg thing Link to comment Share on other sites More sharing options...
escortcabrioletclub Posted April 7, 2008 Share Posted April 7, 2008 yes paul Link to comment Share on other sites More sharing options...
Admin Paul Posted April 7, 2008 Author Admin Share Posted April 7, 2008 Ok thats on and tight anything else that would stop battery light coming on? Link to comment Share on other sites More sharing options...
f40 cab Posted April 7, 2008 Share Posted April 7, 2008 bulb Link to comment Share on other sites More sharing options...
escortcabrioletclub Posted April 7, 2008 Share Posted April 7, 2008 yes that would do it andy Link to comment Share on other sites More sharing options...
escortcabrioletclub Posted April 7, 2008 Share Posted April 7, 2008 what taz said Link to comment Share on other sites More sharing options...
Guest Matt_Norwich Posted April 7, 2008 Share Posted April 7, 2008 I agree !!!! Link to comment Share on other sites More sharing options...
Guest Eggsy Posted April 8, 2008 Share Posted April 8, 2008 bulb PMSL Link to comment Share on other sites More sharing options...
Guest sjc Posted April 8, 2008 Share Posted April 8, 2008 all the above....if Im reading the drawing of the dials right...... with key in, engine off but lights on, the blue wire is in effect the return to earth not the feed. The Alternator, Oil Pressure, Choke, ABS and Handbrake are all off the same feed, so they have to be working. The blue wire is also connected to the heated windscreen relay B/Y wire. Link to comment Share on other sites More sharing options...
Admin Paul Posted April 8, 2008 Author Admin Share Posted April 8, 2008 So if i put that wire to ground it should put the light on? If it does its the alternator at fault. If it doesnt then poss bulb out? Paul Link to comment Share on other sites More sharing options...
Guest sjc Posted April 8, 2008 Share Posted April 8, 2008 (edited) i would say so....ignition has to be on with other red lights up...worst will happen is fuse 17 goes Edited April 8, 2008 by sjc Link to comment Share on other sites More sharing options...
Admin Paul Posted April 23, 2008 Author Admin Share Posted April 23, 2008 Ok, went back to this problem. If i put a piece of wire between housing and good earth battery light comes on. This would indicate the alternater is not earthed very good to the body and after several start ups of the car the battery is dead so would also indicate that it requires a earth to charge the battery. Would i be right?? It appears that the alternator gets its -ve from teh bracket bolted onto the engine block? or does it have a seperate earth wire? I think the problem is the bracket and heat sheild are powder coated and i think this is the problem. Can i take a -ve from the alternator directly to the body if so what guage wire? Paul Link to comment Share on other sites More sharing options...
