Guest barry1974 Posted March 21, 2008 Share Posted March 21, 2008 HELLO ALL. JUST BOUGHT A 1990 G PLATE XR3I CAB. 2 TONE IN COLOUR. MAROON OVER SILVER. PROBLEM I HAVE GOT IS THAT THE ROOF DOES NOT CREATE A SEAL BETWEEN THE REAR WINDOWS AND THE WINDOW SEALS. THERE IS APPROXIMATELY A 10 MM GAP UP THE SIDE OF THE REAR WINDOWS. CAN ANYONE EXPLAIN HOW I CAN ADJUST THE ROOF TO CURE THIS PROBLEM? JUST STARTED CLEANING UNDER THE BONNET READY FOR SOME SUMMER FUN!! THIS SHELL HAS SURVIVED THE YEARS VERY WELL AND MUST BE 1 OF THE CLEANEST TOTALLY ORIGINAL CABS LEFT OUT THERE. TOTALLY ORIGINAL PAINTWORK, WHEELS, TRIM ETC.. ETC.. ANY ADVICE WOULD BE MUCH APPRECIATED!! Link to comment Share on other sites More sharing options...
Guest ANDYA Posted March 21, 2008 Share Posted March 21, 2008 Hi Barry, you're most welcome. Can you get better pics of the affected area? Andy Link to comment Share on other sites More sharing options...
Guest barry1974 Posted March 21, 2008 Share Posted March 21, 2008 HELLO ANDY. WILL GOTO MY DADS TOMORROW AND TAKE PICTURE OF THE ROOF/WINDOW ISSUE AND POST ON HERE. MANAGED TO PINCH BACK HIS GARAGE!! LOL CHEERS, BARRY Hi Barry, you're most welcome. Can you get better pics of the affected area? Andy Link to comment Share on other sites More sharing options...
Guest SG1 Posted March 21, 2008 Share Posted March 21, 2008 Welcome to the club mate. Look forward to seeing some more pics,looks nice so far Have fun. Steve. Link to comment Share on other sites More sharing options...
chaz Posted March 21, 2008 Share Posted March 21, 2008 Welcome to cabbyland mate, cab sure looks minty so look after it and have fun. Link to comment Share on other sites More sharing options...
Guest barry1974 Posted March 21, 2008 Share Posted March 21, 2008 CHEERS FOR THE COMMENTS!! SURE IT WILL LOOK THE PART ONCE I SCRUBBED IT ALL UP!! WILL ADD SOME PICTURES OF HOW THE ROOF FITS, ANY ADVICE HOW TO ADJUST WOULD BE MUCH APPRECIATED. BARRY Welcome to cabbyland mate,cab sure looks minty so look after it and have fun. Link to comment Share on other sites More sharing options...
Guest barry1974 Posted March 21, 2008 Share Posted March 21, 2008 MORE PICS Link to comment Share on other sites More sharing options...
Guest ANDYA Posted March 22, 2008 Share Posted March 22, 2008 Barry, Your car looks really great. Having looked at the pics, there's nothing obvious with regard to the gap you mention. In fact, your roof sits much better than mine! Couple of ideas; 1. Click on 'Community' at the top of this webpage. Select 'Downloads', then 'Technical Information'. In this section you'll see there is a downloadable 'Roof Fitting Guide'. I've already gone through this and the only bit that you might have missing or badly placed appears to be the sealing strips to the rear side windows. This is near the end of the fitting guide. 2. Before you do anything, assuming these bits are in place, try and open and close the roof a few times. If it is very stiff, it may be that the mechanism is not fully extending or retracting. Try a little WD40 on the 'elbow hinges' as you open and close the roof. Hope this helps. Andy Link to comment Share on other sites More sharing options...
Guest barry1974 Posted March 22, 2008 Share Posted March 22, 2008 HELLO AGAIN. BEEN AND TOOK SOME PICTURES OF THE ROOF FIT TO THE REAR WINDOWS. ANY IDEA HOW TO CLOSE THE GAP BETWEEN THE SEALS AND THE REAR WINDOWS?? Link to comment Share on other sites More sharing options...
Guest ANDYA Posted March 22, 2008 Share Posted March 22, 2008 Barry, I went and looked at mine. The sloping edge of your window should fit in to a rubber edging that is attached to the roof. Judging by the gap I think this may be missing. The detail at the end of the 'Roof Fitting Guide', I mentioned on my last post shows these. Have a close look at your car. Does it have these rubber strips? If the strips are all there, you may have to adjust your rear windows, they may have been incorrectly aligned at some time. The whole window assembly would need to be moved backward. I still think the missing rubber strips are more likely, as you don't have much horizontal adjustment on the rear windows, otherwise you create a gap on the front vertical leading edge. Let's know what you find. Good luck with it. Andy Link to comment Share on other sites More sharing options...
Guest barry1974 Posted March 22, 2008 Share Posted March 22, 2008 THANKS FOR THE ADVICE ANDY I WILL CHECK THIS WHEN I GOT MY OLD MAN'S TOMORROW. I WILL REPORT BACK ON WHAT I FIND Link to comment Share on other sites More sharing options...
Guest ANDYA Posted March 22, 2008 Share Posted March 22, 2008 Good stuff, try and get more close ups of the gap if you can. Andy Link to comment Share on other sites More sharing options...
Guest ANDYA Posted April 5, 2008 Share Posted April 5, 2008 Any joy with the roof problem, Barry? Andy Link to comment Share on other sites More sharing options...
Guest barry1974 Posted May 2, 2008 Share Posted May 2, 2008 Hello all, fixed the issue with my cab roof today. The side tensioning cables had snapped on both sides. Bought 2 cables for £16 off the net and fitted today. roof now closes correctly!! Yippeee. Link to comment Share on other sites More sharing options...
chaz Posted May 2, 2008 Share Posted May 2, 2008 Good to hear that mate, hope you now get the weather to use it with the roof down. Link to comment Share on other sites More sharing options...
Guest ANDYA Posted May 2, 2008 Share Posted May 2, 2008 Good Job Barry. Andy Link to comment Share on other sites More sharing options...
