Guest Eggsy Posted February 13, 2008 Share Posted February 13, 2008 this is more along the electrical side of things - ECU I was thinking of using OFAB with the 195 chip, obviosly with already being efi the engine loom should be ok? So is it just a case of swapping the ECU & a remap? The engine in question is a 1.8 zetec. Will be plugging many people for info - but if any of you's on the grapevine know the answer to my dilema any info would be gratefully appreciated. Many thanks The Eggsy Fella Link to comment Share on other sites More sharing options...
Guest Eggsy Posted February 14, 2008 Share Posted February 14, 2008 bump Link to comment Share on other sites More sharing options...
Guest Eggsy Posted February 14, 2008 Share Posted February 14, 2008 ok then so nobody knows - so I'm guessing then If you want to use the EFI wiring & ofab ecu - you'll have to use the rst 8v cylinder head as the system thats on it now will only support 16v. On the other hand with a bit of fettling there shouldn't be any reason why the cozzi 16v management etc should be able to be used??? ANY SUGGESTIONS ??????????????????? Link to comment Share on other sites More sharing options...
Guest cabbydaz Posted February 14, 2008 Share Posted February 14, 2008 hahahaha that would be telling Link to comment Share on other sites More sharing options...
Guest turbocabbie Posted February 14, 2008 Share Posted February 14, 2008 The problem with OFAB and OFAC is that should you wish to use it for zetec or high power there are few people who can custom map this due to the expense of the equipment to do so.. Amhed Bajoo is one who got his system given to him by Ford and Stu from MSD in Blackpool are the only two that I know of who own this equipment... which obviously keeps mapping prices reasonably high...... but it does run 16v OK Cossie management would be fab for this purpose, find someone breaking a saffire and nick the loom and your sorted... Any ECU of L6 and above is perfect as you can run coil pack on these for a more reliable ignition system. I use the FRST inlet for the Zetec turbo's as I have seen well over 300 bhp using these Run a trigger wheel for the crack and cam sensor and your well away Want pics off the bits ? Link to comment Share on other sites More sharing options...
escortcabrioletclub Posted February 14, 2008 Share Posted February 14, 2008 it dont mater it 8v 16v 24v 36v 124v , the ecu will cope the only time it will not is if its 5 cilinder or 6 cilinder or more efi turbo manigment for a 4 cilinder will work on a efi turbo 4 cilinder see how it works ? Link to comment Share on other sites More sharing options...
Guest turbocabbie Posted February 18, 2008 Share Posted February 18, 2008 (edited) To sensor and trigger wheel setup visible Crankshaft Sensor and trigger wheel That's all the timing needs, for a CVH, Zetec, etc.. trigger wheels and senors Notice the nice sexy braided loom Edited February 18, 2008 by turbocabbie Link to comment Share on other sites More sharing options...
Guest Eggsy Posted February 18, 2008 Share Posted February 18, 2008 To sensor and trigger wheel setup visible Crankshaft Sensor and trigger wheel That's all the timing needs, for a CVH, Zetec, etc.. trigger wheels and senors Notice the nice sexy braided loom yes as damn near the same setup on my 1.9 cvh wich also has a sexy braided loom! lol Link to comment Share on other sites More sharing options...
Escort Cabriolet Club Posted February 18, 2008 Share Posted February 18, 2008 Great info guys, all handy, keep it coming !!! Link to comment Share on other sites More sharing options...
Guest markeyboy Posted February 21, 2008 Share Posted February 21, 2008 right its linky time zetec-turbo.co.uk zetecturbo.com turbo.me.uk i dont know anything technical but these sites do have some good pics lol Link to comment Share on other sites More sharing options...
Guest Eggsy Posted February 21, 2008 Share Posted February 21, 2008 right its linky time zetec-turbo.co.uk zetecturbo.com turbo.me.uk i dont know anything technical but these sites do have some good pics lol THANKS MARKEY :icon_salut_gb: Link to comment Share on other sites More sharing options...
Guest markeyboy Posted February 21, 2008 Share Posted February 21, 2008 any time dude Link to comment Share on other sites More sharing options...
