Guest peterw1983 Posted January 4, 2008 Share Posted January 4, 2008 I have had a engine diagnostic test run on the car and they have told me the engine speed sensor is faulty ( hopefully if i locate it and change it the car will stop stopping at junctions ) so if some one can tell me where it is or send me a pic of what it looks like would be most grateful cheers again pete Link to comment Share on other sites More sharing options...
f40 cab Posted January 4, 2008 Share Posted January 4, 2008 what mk/year car is it and engine? Link to comment Share on other sites More sharing options...
Guest markeyboy Posted January 4, 2008 Share Posted January 4, 2008 there is a sensor that is connected to the fly wheel, this would prob be the one you are talking about. its located on the right hand side of the engine (front side) quite low down. good luck fella Link to comment Share on other sites More sharing options...
Guest peterw1983 Posted January 4, 2008 Share Posted January 4, 2008 its a mk 4 1989 on a g reg xr3i cabriolet cheesr pete Link to comment Share on other sites More sharing options...
Guest bigjon Posted January 4, 2008 Share Posted January 4, 2008 hi mate its the sensor which is on top of the gearbox which the speedo cable goes into.i had the same problem as u got when my car was xr3i hope this helps Link to comment Share on other sites More sharing options...
Vincygav Posted January 6, 2008 Share Posted January 6, 2008 As said above its on the gearbox and the speedo cable goes into it. Also known as a VSS Vehicle Speed Sensor. Link to comment Share on other sites More sharing options...
Guest peterw1983 Posted January 6, 2008 Share Posted January 6, 2008 have changed this part now still the car keeps on stopping but cheers to all that helped locate cheers pete Link to comment Share on other sites More sharing options...
