Guest matt-the-dj Posted December 27, 2007 Share Posted December 27, 2007 hi guys merry christmas i have a slight prob with my cab it has been getting hard to start lately, i turn the key, ignition lights up but i turn it one more and nothing no starter turning, until today i tried it a couple of times then it worked, but now it will not turn over at all, so my question is do you think the starter switch is faulty and should i change the ignition relay at the same time, can i bodge it to test my theory.I have checked the terminals of the switch and im not getting a feed on the black/blu wire which goes to the starter, but im not sure if the relay could throw this fault up please help. i have to fix it urgently as my mondeo has a slipping clutch. doh! Link to comment Share on other sites More sharing options...
Vincygav Posted January 6, 2008 Share Posted January 6, 2008 I had this problem, I changed the ignition switch, Many of the original items tended to go faulty after and if you buy a new one you would see it is slightly different. Link to comment Share on other sites More sharing options...
Guest matt-the-dj Posted January 6, 2008 Share Posted January 6, 2008 (edited) well, went out there to find and fix fault but now car starts ok , so now i have to wait till it goes again to sort it, bloomin thing!!!!!!!!!!!!!!!! :convertible_mazeguy: Edited January 6, 2008 by matt-the-dj Link to comment Share on other sites More sharing options...
Guest DUANE Posted January 28, 2008 Share Posted January 28, 2008 i had the same on mine it was the back of ignition the cap kept moving just a little but enough for it to light up dash but not turn the engine i took the cover off and found a clip broke iam still having to hold it on when i turn the key will put a new one on at some point Link to comment Share on other sites More sharing options...
