Guest marv69 Posted December 16, 2007 Share Posted December 16, 2007 (edited) quick question is it a straight swap to change a 1994, 1600 zetec to a 1800 zetec if not what am i needing to do ? thanks. Edited December 16, 2007 by marv69 Link to comment Share on other sites More sharing options...
Guest steelcabby Posted December 16, 2007 Share Posted December 16, 2007 as far as i know it is the same, but someone else will need to back me up on this.. have you got the hole 1800 zetec engine, ie inlet, exhaust manifold, etc etc?? if not the i will have a full 1800 16v zetec convertion going soon. engine, inlet, exhaust manifold, wiring, full exhaust, and gearbox etc.. G Link to comment Share on other sites More sharing options...
Guest marv69 Posted December 16, 2007 Share Posted December 16, 2007 (edited) yes i have everything. hopeing to get this done just after new year and hoping for an easy swap would u surgest to lift the engine and box out the top togeather and same for putting it back in ? or drop the sub frame ? Edited December 16, 2007 by marv69 Link to comment Share on other sites More sharing options...
Guest steelcabby Posted December 16, 2007 Share Posted December 16, 2007 I would say if you have a hoist it would be easier to lift from the top with your bonnet off of course.. alot of people just drop the sub-frame, but then you still have to get the bugger out from underneath.. just unbolt it from the sub-frame and hoist it from the top mate, then drop the new one in from the top too. i would say thats easiest. make sure you have the whole engine assembled before you drop it in so its less to put on when its in. Link to comment Share on other sites More sharing options...
Vincygav Posted January 6, 2008 Share Posted January 6, 2008 Think you would also need the fusebox and ECU Link to comment Share on other sites More sharing options...
Guest tippers Posted January 15, 2008 Share Posted January 15, 2008 I fitted a 1.8 zetec rs1800 lump into my mk5 after taking out cvh lump to put in a MK4 CAB.All you would need is the ecu wiring is the same as is fuse box im still running fuse box from my cvh and it works fine. Link to comment Share on other sites More sharing options...
