Mk 6 Cabby Fog Light And Horn!
Guest steveoiow
Guest steveoiow
hi guys
got a wierd one here :- mk 6 escort cabby 97 when you put the front fog lights on the horn sounds continuesly until you switch them off just started doing it yesterday !
funny but annoying
any clues ?
cheers
Guest steveoiow
no horn works fine lights dont flash
when the horn is on continusely you can press the horn button on the wheel and it still honks but then goes back to continuesly
Guest matt-the-dj
check your wiring especially the earths, possibly fog lights are some how wired in series with hooter, so when the lights are on it is then drawing current thru horn causing the problem, are you using the existing wiring loom or is it some wires you added.
