Guest RSkiplandeRS Posted November 6, 2007 Share Posted November 6, 2007 Hi Guys Got a strange prob. When I depress brake pedal Interior lights come on and front side lights and rear side lights. Have checked all earths and changed indicator light stalk also added earth wire to rear light cluster. No change. Once you have turned car off and taken keys out if you keep your foot on the brake pedal the car continues to run. lately when tryin to start car once you turn keys in ignition it continues to krank by itself and you have to disconnect from battery to stop kranking. car does not start whist doing this. Link to comment Share on other sites More sharing options...
Guest markeyboy Posted November 6, 2007 Share Posted November 6, 2007 check that you have got the correct bulbs in the correct holders, happend to m8 m8s fiesta years ago, think it was one of his brake light bulbs that was causing the problem, took ages to work out tho and was hileariously funny to watch when he was driving down the road Link to comment Share on other sites More sharing options...
Guest Eggsy Posted November 6, 2007 Share Posted November 6, 2007 also take the cowls of & check that the black cap behind the ignition is not worn ?? Link to comment Share on other sites More sharing options...
Vincygav Posted November 6, 2007 Share Posted November 6, 2007 Also check the fusebox or ignition relay aint gone. Link to comment Share on other sites More sharing options...
