Guest DAZZADAMONDEOMAN Posted November 4, 2007 Share Posted November 4, 2007 Hi all, i have had this escort cab for just over 2 months now, everything has been fine on it, but about 4 days ago, the other half said the battery light was on,. so i checked the fuses and the one from bottom left in the fuse box had bown so i changed it, that lasted 10 mins, then the next day i changed it again it last 4 hours, she drove home from work at 9pm with no lights, cause when this fuse blows you lose headlights, brakelights,dashlights just the battery light comes on, and the fuse pops when you put the key in the ignition and turn it on click from start, any ideas people please, need to sort it .A.S.A.P. cheap as well cant be paying stupid electricians to cum and cut wires, when i can do that my self, hope to hear from some one A.S.A.P thanx all regards Darren Lever ( DAZZADAMAN ) Link to comment Share on other sites More sharing options...
Escort Cabriolet Club Posted November 5, 2007 Share Posted November 5, 2007 You might have a lose wire or a bad earth somwhere, I would check 'EVERY' front and rear bulb to make sure all the bulbs and wires are secure, check for signs of rust on the rear light bulb board contacts !!! Link to comment Share on other sites More sharing options...
Guest DAZZADAMONDEOMAN Posted November 5, 2007 Share Posted November 5, 2007 You might have a lose wire or a bad earth somwhere, I would check 'EVERY' front and rear bulb to make sure all the bulbs and wires are secure, check for signs of rust on the rear light bulb board contacts !!! Thanx for the advice, think i sorted it now, i pulled the fuse box down this morning and checked the wires and all the fuses, and took the fuse wire bar out the fuse box to check the wire lines and all seems fine, but i did find a green 30 amp fuse that was blown that was with a relay!!! which could have been it,and i changed the fuse that kept blowing all the time again, and found another 1 or 2 fuses blown, and then i put it all back 2gether, and all worked fine again, but the rear fog lights dont work now, the switch isnt lighting up nor are the actual lights on the back, any ideas. i dont wanna pull the fuse box out again incase i trip the fuse out or sumthing again. thank you again regards DAZZADAMAN. Link to comment Share on other sites More sharing options...
Guest DAZZADAMONDEOMAN Posted December 1, 2007 Share Posted December 1, 2007 OK PROBLEM HAS STARTED AGAIN, I KNOW IT ISNT THE BRAKE LIGHT BULBS OR HEADLIGHT BULBS!!! SO IT MUST BE IN THE DASH WIRING, ANY ONE GOT ANY EASY IDEAS. I CHANGED A VAUXHALL NOVA DASH LOOM 4 YEARS AGOM AND I CHANGED MY MONDEO DASH LLOM LAST YEAR, IS IT AS EASY AS THEM DOES ANY ONE KNOW!!! Link to comment Share on other sites More sharing options...
Vincygav Posted January 6, 2008 Share Posted January 6, 2008 Check all the wirings in the boot or it may be time for another fusebox, maybe the tracks inside it are burnt somewhere. Link to comment Share on other sites More sharing options...
Guest fluffy Posted January 6, 2008 Share Posted January 6, 2008 it sounds to me m8 that its arcin out on the postive point check all postive and negtive point on ur cars battery and interior lights etc aswell as doin that tighten up the groundin cables on ur boot & bonnet if it keeps doin it then make its ur car body thats it not good enough to make a complete circut u can solve this problem by makin a new earthin points and gettin rid of any rust on ur cars body Link to comment Share on other sites More sharing options...
Guest rs-steve Posted January 6, 2008 Share Posted January 6, 2008 friend had the same trouble with his mk5 turned out to be fuse box was kaput changed that and sweet Link to comment Share on other sites More sharing options...
