Guest really_mike Posted October 29, 2007 Share Posted October 29, 2007 Hi ive finally fitted the induction kit to my escort zetec 1.8, sounds sooooo goood But i also fitted a performance exaust around a week ago and im wondering if i need to get the engine tuned, like the ECU to get more performance out of it with the aid of the induction kit an the exaust? Mike. Link to comment Share on other sites More sharing options...
Guest Eggsy Posted October 29, 2007 Share Posted October 29, 2007 Decomp plate, frst loom & strap a turbo to it!! :icon_salut_gb: Link to comment Share on other sites More sharing options...
Guest tom Posted October 30, 2007 Share Posted October 30, 2007 uprated brakes - discs, pads, callipers, braided brake lines, then suspension properly set up we can all drive fast but stopping gets harder. and handling is as important as going fast Link to comment Share on other sites More sharing options...
Guest markeyboy Posted October 30, 2007 Share Posted October 30, 2007 i dont think theres to much ya can do with the ecu, i think it kinda looks after its self, got a simular set up on mine at the mo, decat should see ya some more power tho Link to comment Share on other sites More sharing options...
escortcabrioletclub Posted October 30, 2007 Share Posted October 30, 2007 uprated brakes - discs, pads, callipers, braided brake lines, then suspension properly set up we can all drive fast but stopping gets harder. and handling is as important as going fast so true tom ... after doing that you can de cat ... put a fse valve on and bigger throttle body better plugs and leads cams vernia pullys chip the ecu .. theres loads that can be done Link to comment Share on other sites More sharing options...
Guest really_mike Posted October 31, 2007 Share Posted October 31, 2007 following what 'eggsy' said about a turbo, arn't they expensive, plus a turbocharger would need alterations to the exaust pipes and i cant see that being cheap to install. also ive heard they need quite a bit of cooling too so thats more money for an intercooler? it would be good to make it faster but i want fast acceleration too. Link to comment Share on other sites More sharing options...
Guest markeyboy Posted October 31, 2007 Share Posted October 31, 2007 turbo conversions r expensive m8, seriously looked into doing one myself, youll struggle to get it done for under 1k Link to comment Share on other sites More sharing options...
Guest Dazzaas Posted November 1, 2007 Share Posted November 1, 2007 put a 2ltr throttle body and maf sensor on done that to mine makes the induction really ROAR love the noise it makes now Link to comment Share on other sites More sharing options...
Guest Matt_Norwich Posted November 11, 2007 Share Posted November 11, 2007 i found the best way to unlock some power with out too much messing or spending was: induction kit, back box, de cat, 4 branch manifold, 2L 136ps mondeo cam shafts throttle body and MAF, power boost valve(may have to replace the fuel pump for this depends on how tired it is) and a super chips module for the ecu. Ok not as quick as a turbo but put a smile on my face when i left my mates civic crx behind ) Link to comment Share on other sites More sharing options...
Guest ajs_20 Posted January 24, 2008 Share Posted January 24, 2008 Hi mate don't mean to sound harsh here but if its a late zetec in a Mk6 then remove it and put it back in the box! An aftermarket panel filter with extra cold air feed can gain just as much and I've proved that on 4 Zetecs. The 2.0 Throttle body and MAF are only worth it if you are goin to do the 2.0 cams which is where things start to cost a bit more. Decats do help but they often knacker Lambda sensors quick, mess up ya fuel settings and basically make it drink a hell of a lot more! Superchip is a good start, FSE powerboost may be worth a try and a manifold! Link to comment Share on other sites More sharing options...
