Guest eskey5 Posted October 22, 2007 Share Posted October 22, 2007 Ive just cleaned and hoovered the car, when i took the mat out of the passenger footwell i discovered it's soaked :sad anyone have any ideas whats wrong.......................? Link to comment Share on other sites More sharing options...
Vincygav Posted October 22, 2007 Share Posted October 22, 2007 Check the door drain holes aint clogged up with muck, then next the sill drain holes, stick something like a coathanger end up in it to clear it. Other place is behind the wheelarch liner near the sill. Link to comment Share on other sites More sharing options...
Guest Terry6680 Posted December 19, 2007 Share Posted December 19, 2007 I had the exact same problem a couple of weeks ago, i was cleaning out my car after the rain, i soon realised that the footwell of the passenger floor was soaked, i couldnt see any water marks on the inside as to where the water was dripping down from, i inspected the rubber seals around the door and window and saw that everytime i was shutting the passenger door, it was catching the rubber trim above the door and making it gradually pop out, therefor leaving an area to have water running in and down the side of the door and then onto thr carpet, i had to get the old hair dryer out and heat up the rubber seals and use a blunt knife to push the seals back into thier normal position, i havent had a problem since! i would suggest you check all of the rubber seals around the door area, especially the strip leading parallel with the roof and see if anything has popped out, also, see if the rubber trim that the top of your window sits in when it is fully up is being caught and leaving a gap for water to get in!? Link to comment Share on other sites More sharing options...
Guest Eggsy Posted December 19, 2007 Share Posted December 19, 2007 also check battery tray ? Link to comment Share on other sites More sharing options...
Admin Paul Posted December 19, 2007 Admin Share Posted December 19, 2007 battery tray, Link to comment Share on other sites More sharing options...
Guest eskey5 Posted December 21, 2007 Share Posted December 21, 2007 Yeah it looks like it's the battery tray, anyone know where i can get a new one from..............? Beckie Link to comment Share on other sites More sharing options...
Guest Eggsy Posted December 21, 2007 Share Posted December 21, 2007 try ebay or a local panel specialist/motor factors Link to comment Share on other sites More sharing options...
Guest Eggsy Posted December 21, 2007 Share Posted December 21, 2007 http://www.rsturbos.com/store/index.php?ma...e65f5183bc20e49 Link to comment Share on other sites More sharing options...
