Guest SortedLX Posted October 12, 2007 Share Posted October 12, 2007 On mine its constantly on, its only started today after I did some welding on it on the seat mounts. Havent touched any electrical bits. Mines an mk5, Any ideas? Cheers Andy Link to comment Share on other sites More sharing options...
escortcabrioletclub Posted October 13, 2007 Share Posted October 13, 2007 did you disconcet the battery when you did the weilding ? Link to comment Share on other sites More sharing options...
Guest Eggsy Posted October 13, 2007 Share Posted October 13, 2007 That is the problem Link to comment Share on other sites More sharing options...
Guest matt-the-dj Posted October 13, 2007 Share Posted October 13, 2007 if the light stays on there is a fault, it should stay on for about 15 to 20 secs when you switch on ignition then go out. i will look in me haynes to see if there is some idea what the fault is. :convertible_mazeguy: Link to comment Share on other sites More sharing options...
Guest SortedLX Posted October 14, 2007 Share Posted October 14, 2007 Did leave the batt connections on, altho it wasnt me weldin it was a mate. What should I do now? reset the ecu? How? Cheers Andy Link to comment Share on other sites More sharing options...
