Bit More Info On Amps Please
f40 cab
hi never done much with car ice systems before so thought i would start this year, got cheap amp to play with, but what does the gain dial do and where should i have it full ,half. ok and theres a boost switch on or off cant hear any difference . and theres a socket for high gain input what the hell do i put in there. lol. thank you. for your hep.
Guest markeyboy
the gain is generally the volume controle on the amp, it increaces the signel size.
you need to have a play about with it untill you get the best sound out of the speakers
the boost function is generally another signel booster
not to sure about the high gain bit tho
the gain you should have @ 1/2 as any higher & it seems to amplify distortion!
boost is usually bass boost for a sub, high input is for when you put your speaker wires into the amp instead of rca's
hope this is of a bit of help andy!! lol
if you want a quick rule of thumb for gain (if your using the amp for a sub)....
put on some of your favourite usual music
turn the stereo up 75%...ie if the volume goes to 30 put it around 22/23
increase the gain until the amp starts to loose control of the sub (distortion)
turn it down a bit
job done
