Cab Broken Into
Guest trickyrick
Guest trickyrick
came to my cab this morning and saw it was broken into, all locks were screwed, the ignition barrel was ripped out and the swicth was used to try and start, replaced all the locks with ease apart from the ignition barrel.
i can only get the new one to turn only 1 click the the I (when its in the barrel) take it out and its fine can turn to III
When on O the steering lock is a bit iffy!
need to get ignition switch working properly
Pleaseeeee Help!!!!
Thanks Rick.
Edited by trickyrick
its the ignition housing i need, (thats what i meant)
If its that how much u want for it?
have they snapped the steering lock??
do you need the cowels too??
Edited by Eggsy
Guest trickyrick
the steering lock itself was not broken. they hammerd and chiseled at the lock itself, and broke something inbetween the lock and the actuall switch, (i dont really know what the things riound there are called)
give me a ring mate on 07999904086 & try and descirbe what u need as i do have all the parts to repair! :icon_salut_gb:
  • 1 month later...
Guest rs-steve
thieving pikeys they should be caught lined up and shot good luck getting it fixed though
Edited by rs-steve
