Blower Problem
Guest dragon46
Guest dragon46
hi guys and gals, my blower don't work, fuse and switch are ok, the problem is there is no power getting to the switch, can u help, cheers
Guest matt-the-dj
is it a mark 5 , by any chance, all though the fuse is good .......check when the fuse is in by putting your meter on the metal of the fuse and check each piece of metal to earth you should see 12v.......if it is the same fault as my mk 5 its the fuseboard.......if so let me know and ill show u a temp fix.
Guest dragon46
hubby been out there again tryin to sort me stereo out when something went pop and now the blower works, work that one out, confused.com lol, and yes it is a mk5
Guest dragon46
My blower doesn't work either! and yeah its a mk5b! temp repair would be great but really i need a new fuse box!
hi tracy, do u want me to send hubby round to see if he can make your car go pop then the blower mite work again lmao
Guest matt-the-dj
tracey, when you have a mo pm me ill give u my mobile and talk you thru the quick fix......im an electrical lecturer (pfrofessional electrician) so i can blow it up proper pmsl
Guest matt-the-dj
sounds like a loose lead behind the radio and you disturbed it and shorted it to earth(bodywork)
obviosly a curse on the mk5 mine dont work either checked switch and fuses just assumed it was the motor wot else could be the problem and ill check cheers
  • 3 weeks later...
