Guest shaunie Posted September 19, 2007 Share Posted September 19, 2007 hi guys hope you can help here i brought a cabbie solar with dead engine so after fitting new engine it runs sweet as a nut the problem i have is from alternator there is a blue lead that runs up to bulkhead but can not seem to find where it goes i have no battrey light on my dash lighting up and it seems to kill my battrey it seems like it is charging when it feels like it but i have a funny feeling its something to do with this blue wire it comes from alternator but i dont know where it goes any ideas anyone before the chemist kick me out for buying all thier hair regrow lol Link to comment Share on other sites More sharing options...
Guest matt-the-dj Posted September 19, 2007 Share Posted September 19, 2007 what year is it,ill have a look in my haynes if its the right year for the book Link to comment Share on other sites More sharing options...
Guest shaunie Posted September 19, 2007 Share Posted September 19, 2007 what year is it,ill have a look in my haynes if its the right year for the book cheers mate sent a pm but it is a M reg 1995 1.6 efi engine Link to comment Share on other sites More sharing options...
Guest matt-the-dj Posted September 20, 2007 Share Posted September 20, 2007 ill have a look this afternoon, if its the right book ill scan the drawings and try and upload them for you. Link to comment Share on other sites More sharing options...
Guest matt-the-dj Posted September 20, 2007 Share Posted September 20, 2007 you could check to see if alternator is charging by putting a meter on the batt terminals,with the engine running you should see appx 14 volts load the system up and as you increase the load you should hear a change in engine note as the load on the alternator increases. good luck Link to comment Share on other sites More sharing options...
Guest shaunie Posted September 20, 2007 Share Posted September 20, 2007 tried that and seems ok but its this blue wire coming from the alternator thats bugging me ( where does it go ) lol lol and i still have no battrey light on dashboard Link to comment Share on other sites More sharing options...
Guest matt-the-dj Posted September 20, 2007 Share Posted September 20, 2007 right mate, if ive done this right the drawings should be attached if not, give me an email adress, the blue wire does run to dash via link in fuseboard,also there is a resistor in line with it check that and check continuity , check you have a working lamp in the dashboard as some bastards pull out the lamp when the alternator goes tits up and light up to show its charging, therefore its lit all the time the engine is running,so they pull out the lamp and hope you dont notice when you switch on ignition regards matt see post re: lights PICS FILE TOO LARGE NEED EMAIL ADRESS Link to comment Share on other sites More sharing options...
Guest matt-the-dj Posted September 20, 2007 Share Posted September 20, 2007 to make it clear-----the resistor is in the dashboard wired in with the dash charge light Link to comment Share on other sites More sharing options...
escortcabrioletclub Posted March 28, 2008 Share Posted March 28, 2008 nice advice there did you get it sorted as no more was mentioned ????? nice one matt Link to comment Share on other sites More sharing options...
Guest shaunie Posted March 28, 2008 Share Posted March 28, 2008 nice advice there did you get it sorted as no more was mentioned ????? nice one matt nope it ended up going into a garage and sorted out there Link to comment Share on other sites More sharing options...
escortcabrioletclub Posted March 28, 2008 Share Posted March 28, 2008 so it got fixed what was it info you may want to sheare for others in the future ?????? Link to comment Share on other sites More sharing options...
