Guest daKlone Posted August 13, 2007 Share Posted August 13, 2007 Has anyone done it? If so, what parts of the fuel system did you keep (if any) and what did you replace? Link to comment Share on other sites More sharing options...
Guest reggyreg Posted August 14, 2007 Share Posted August 14, 2007 Has anyone done it? If so, what parts of the fuel system did you keep (if any) and what did you replace? hi if your keeping as a mfi you can ouly change the bottom end (zvh conversion) as the zetec head doesn't have a dizzy you will need the bottom end altering to fit the cvh head if need any more info just ask me Link to comment Share on other sites More sharing options...
Guest daKlone Posted August 15, 2007 Share Posted August 15, 2007 hi if your keeping as a mfi you can ouly change the bottom end (zvh conversion) as the zetec head doesn't have a dizzy you will need the bottom end altering to fit the cvh head if need any more info just ask me Hi - thanks for the info but I was intending to replace the whole CVH with the Zetec. According to the specs in the Haynes book the MFI system is capable of delivering 1.4 litres per minute at 3.5 - 4.5 bar pressure, but doesn't have a pressure regulator. So it seems to me that I can keep the fuel tank, filter, pump and accumulator from the old MFI system, add a pressure regulator and that would do the trick. Am I missing something (probably blindingly obvious!!)? Link to comment Share on other sites More sharing options...
escortcabrioletclub Posted August 15, 2007 Share Posted August 15, 2007 Am I missing something (probably blindingly obvious!!)? well apart from one is mfi and one is efi ........... all you need to do fuel wise is put the pipe from your pump onto the zetec fuel rail and job done ...... Link to comment Share on other sites More sharing options...
Guest daKlone Posted August 15, 2007 Share Posted August 15, 2007 Am I missing something (probably blindingly obvious!!)? well apart from one is mfi and one is efi ........... I knew that, smartass! :happy001: all you need to do fuel wise is put the pipe from your pump onto the zetec fuel rail and job done ...... So I was right then...sweet! Thanks dude! :big_wave: Link to comment Share on other sites More sharing options...
Guest no2lurch Posted August 16, 2007 Share Posted August 16, 2007 I knew that, smartass! :happy001: So I was right then...sweet! Thanks dude! :big_wave: surely if you take the whole mfi engine out, all you will be left with is the tank and pipes as the pump on mfi engines is bolted to the block aint it? therefore i think you'll need an efi tank as the pump is in the tank. oh, and tony is a smart ass because he has done most mods to cabs in the times that he has owned them. if tony cant help, chances are others cant. Link to comment Share on other sites More sharing options...
escortcabrioletclub Posted August 16, 2007 Share Posted August 16, 2007 mfi pump hangs outside just behind the tank efi had pump in the tank pump is nowhere near the engine ...... only the fuel filter is ...... Link to comment Share on other sites More sharing options...
Guest no2lurch Posted August 16, 2007 Share Posted August 16, 2007 mfi pump hangs outside just behind the tank efi had pump in the tank pump is nowhere near the engine ...... only the fuel filter is ...... i stand corrected. thanks tony. i thought the mechanical part came from it working off the engine... Link to comment Share on other sites More sharing options...
Guest turbosy Posted August 17, 2007 Share Posted August 17, 2007 i thought the mechanical part came from it working off the engine... On a non injection engine the fuel pump is mounted on the head & is operated by a push rod off the cam! SY Link to comment Share on other sites More sharing options...
