Guest nickscunny Posted August 3, 2007 Share Posted August 3, 2007 I have a mk6 escort cabriolet and last night my rear drivers side window jammed half way up. Now niether rear window will power up or down. The fronts are perfect but the rears have stopped working. Please some one help, i have 1 window half open and one closed! Nick Link to comment Share on other sites More sharing options...
Guest 6tracy9 Posted August 3, 2007 Share Posted August 3, 2007 i had this problem with my drivers side front window - turns out it was the relay, Have u checked that? Link to comment Share on other sites More sharing options...
Vincygav Posted August 4, 2007 Share Posted August 4, 2007 Check the relay, or even the wire to the rear windows safety switch has not fallen off the connector. The circle button with red window logo on centre console near the handbrake. Link to comment Share on other sites More sharing options...
Guest PFM Posted August 5, 2007 Share Posted August 5, 2007 Also try the centre console drop button attachments I had exactly the same happent to me about a year ago - turned out to be a connection that had worked its way loose. Hope this helps Link to comment Share on other sites More sharing options...
