Guest ferrel Posted September 30, 2015 Share Posted September 30, 2015 (edited) hi im looking to tune up my xr3i a bit, as far as I can see I need throttle body cams and remapping to get to 130 bhp. can anyone give me a detailed description of the process or another route I can take for better results. I want to do the work myself so nothing to taxing also anything else that would need changing even if u think its obvious as I know very little about tuning. I appreciate this has probably been asked a million times before so thanks in advance for anyone who has the time and know how to help Edited September 30, 2015 by ferrel Quote Link to comment Share on other sites More sharing options...
Ian71 Posted September 30, 2015 Share Posted September 30, 2015 A word of advice,before you do anything to the engine have it checked for weir on a rolling road or an experianced mechanic as changing to a high lift cam and remapping can put alot more stress on an old engine. Fitting an rs turbo engine may be a easier in the long run and give you the extra power you are looking for. Good luck. Quote Link to comment Share on other sites More sharing options...
Guest ferrel Posted September 30, 2015 Share Posted September 30, 2015 The engine has done 95000 and has full service history and sounds sweet I do have some good frinds who are custom car builders thatcan assist me. I diddnt want to do a full engine change I know this is the most suggested route, but I am on a budget and want to change things over time. I will get the engine checked out tho makes sense to start with somthing in good shape thanks Quote Link to comment Share on other sites More sharing options...
