Guest no2lurch Posted July 9, 2007 Share Posted July 9, 2007 as its gonna rain later, and as i stopped the roof leaking (i think) i thought sod it, i'll go to work in the cab. when indicating right while braking, the indicator flashes real slow. when indicating right but not btraking, its normal, as is when i indicate left always. is this due to a bad earth? if so, where are the earthing points to check? we were driving te cab all weekend but didnt notice any problems. i drove 150 miles yesterday with a yrailer on the back, and nothing like it was apparent... cheers in advance. Link to comment Share on other sites More sharing options...
Guest massive Moooooo Posted July 9, 2007 Share Posted July 9, 2007 common problem mate jus take out the lighting board and clean all contacts its usual corasion on the board itself jus give it all a real good scrub but while youve got it out you might as well do your best to clean the connecting block to eliminate any further problems i use a wd40 and a toothbrush does the trick but i must remember looking at my teeth this morning witch toothbrush is witch lol Hope that solves it Lee Link to comment Share on other sites More sharing options...
Guest massive Moooooo Posted July 9, 2007 Share Posted July 9, 2007 OH never thourght it could jus be that youre block maybe a bit lose on the board that should stop it and save you from using the mrs toothbrush too happy days lol Link to comment Share on other sites More sharing options...
Guest no2lurch Posted August 23, 2007 Share Posted August 23, 2007 OH never thourght it could jus be that youre block maybe a bit lose on the board that should stop it and save you from using the mrs toothbrush too happy days lol i took the plug out and cleaned it up. i put a squirt of wd on too, but its still the same. Link to comment Share on other sites More sharing options...
Guest 29 cab Posted September 12, 2007 Share Posted September 12, 2007 as its gonna rain later, and as i stopped the roof leaking (i think) i thought sod it, i'll go to work in the cab. when indicating right while braking, the indicator flashes real slow. when indicating right but not btraking, its normal, as is when i indicate left always. is this due to a bad earth? if so, where are the earthing points to check? we were driving te cab all weekend but didnt notice any problems. i drove 150 miles yesterday with a yrailer on the back, and nothing like it was apparent... cheers in advance. i have the very same problem on mine mate, tried cleanind the boards up, cleaned the all the connectors up, even replaced the bulbs, cleaned 6 earths on the car but it still does it. my fog light switch lights up when i brake when the lights are on and when i indecate left the brake/indecator flash like a becon only with the lights on! im stuck as what to do now as ive tried everything i can think of. Link to comment Share on other sites More sharing options...
